Home » Modeling » M2T (model-to-text transformation) » generate code out of metamodel(.ecore file ) using xpandfacade
generate code out of metamodel(.ecore file ) using xpandfacade [message #1223536] Mon, 23 December 2013 12:53 Go to next message
Hi all ,
I am creating plugin that allow the user to generate code out of .ecore file using xpandfacade .
I have probelm of specifying the .ecore file in evaluate function
for example
xpandFacade.evaluate("templates::Template::main", ??????);
i tried the metamodel path but it did not work ?
I appreciate any help ?
Re: generate code out of metamodel(.ecore file ) using xpandfacade [message #1223597 is a reply to message #1223536] Mon, 23 December 2013 17:28 Go to previous messageGo to next message
Hi you have to read the model with emf means yourself
Need training, onsite consulting or any other kind of help for Xtext?
Go visit http://xtext.itemis.com or send a mail to xtext at itemis dot de
[Updated on: Tue, 24 December 2013 18:09] by Moderator
Re: generate code out of metamodel(.ecore file ) using xpandfacade [message #1225069 is a reply to message #1223597] Sat, 28 December 2013 11:50 Go to previous messageGo to next message
Thanks christian ,
I tried your suggestion but I am not sure if I understood completely
If you please could you explain for me the differenc in the registeration of metamodel
.ecore file and instance of it .xmi file as I want to generate code from the both
here is my code of regiseration ,
	    URI uri = URI.createURI("file:///D:/xpand/xpand/my.generator.project/src/metamodel/metamodel.ecore", true);
	    Resource.Factory.Registry.INSTANCE.getExtensionToFactoryMap().put("ecore", new EcoreResourceFactoryImpl());
	    ResourceSet rs = new ResourceSetImpl();
	 // enable extended metadata
	    final ExtendedMetaData extendedMetaData = new BasicExtendedMetaData(rs.getPackageRegistry());
	    rs.getLoadOptions().put(XMLResource.OPTION_EXTENDED_META_DATA,extendedMetaData);
	    EPackage p = null ;
	    Resource r = rs.getResource(uri, true);
	    Object eObject =  r.getContents().get(0);
	    if (eObject instanceof EPackage) {
	      p = (EPackage)eObject;
	     rs.getPackageRegistry().put(p.getNsURI(), p);
                MyOutPutImpl out = new MyOutPutImpl();
		MyOutlet outlet = new MyOutlet("my-gen");
		out.addOutlet( outlet);
		ProtectedRegionResolver prs = new ProtectedRegionResolverImpl();
		XpandExecutionContext execCtx = new XpandExecutionContextImpl(out, prs);
                XpandFacade.create(execCtx).evaluate("template::Template::main", p);
and here my template for generating code from metamodel.ecore
               «DEFINE main FOR ecore::EPackage»
               «EXPAND javaClass FOREACH eClassifiers.typeSelect(ecore::EClass)»
               «ENDDEFINE»
               «DEFINE javaClass FOR ecore::EClass»
               public class «name» {
              «ENDDEFINE»
When I run the project I got this exception
Exception in thread "main" EvaluationException : No Definition template::Template::main for Object could be found!
	                       Internal error : element was null
could you please guide me what I am doing wrong ?
thanks in advance .
[Updated on: Mon, 30 December 2013 15:49] by Moderator
Re: generate code out of metamodel(.ecore file ) using xpandfacade [message #1705591 is a reply to message #1225069] Mon, 17 August 2015 12:45 Go to previous message
I have the same problem but it has an error:
Exception in thread "main" EvaluationException : Couldn't find extension 'getComponentList()'!
template::Template.xpt[172,18] on line 9 '.getComponentList()'
In the java class, i use
String templatePath = "template::Template::definition";
XpandExecutionContextImpl execCtx = new
XpandExecutionContextImpl(out, null);
execCtx.registerMetaModel(new EmfRegistryMetaModel());
XpandFacade facade = XpandFacade.create(execCtx);
facade.evaluate(templatePath, definition, params);
in Template.xpt, i declare:
«IMPORT fractal»
«EXTENSION template::Extensions»
«DEFINE definition FOR Definition»
//call template
«EXPAND component FOREACH getComponentList()»
«ENDDEFINE»
and in the extension file (Extensions.ext), i declare:
import fractal;
Definition definition1(Component this) :
eContainer;
List[Component] getComponentList(Definition this) :
subComponents.typeSelect(Component);
Could you help me please ?
[Updated on: Mon, 17 August 2015 17:25] by Moderator
Previous Topic:[Xtext] updating/writing resource descriptions chunk x of xxx
Next Topic:html Export
Current Time: Tue Jul 01 01:39:32 EDT 2025
Powered by FUDForum. Page generated in 0.05655 seconds
