Home » Language IDEs » ServerTools (WTP) » The AXIS engine could not find a target service to invoke! targetService is Converter
Re: The AXIS engine could not find a target service to invoke! targetService is Converter [message #178193 is a reply to message #178177] |
Tue, 29 August 2006 19:31 |
Originally posted by: lenzi.jimmy.harvard.edu
yay, thanks for replying.
yes, I followed that tutorial and Eclipse successfully created
everything, both the ConverterProj and the ConverterClientproj with all
the JSPs. It deployed to Tomcat and loaded in the browser. I typed in a
Celsius value and got that error. I didn't do anything else.
Here is a screen shot that shows the error message when I type in a
value into the test JSP
http://slenzi.smugmug.com/gallery/1829874/1/91531693/Large
Here is another screen shot that show the same thing only this time I
used the Web Services Explorer and accessed the service via the WSDL file.
http://slenzi.smugmug.com/gallery/1829874/1/91531704/Large
Still pretty much stuck. I was reading around a bit, kinda new to web
services, but could the deploy.wsdd file be wrong? I'm grasping at
straws here.
Seth
Gilbert Andrews wrote:
> Seth wrote:
>> Hello, I am getting the following error message when I try a test a
>> simple web service
>> exception: The AXIS engine could not find a target service to invoke!
>> targetService is Converter.
>> I am using the all-in-one Eclipse WTP package,
>> wtp-all-in-one-sdk-R-1.5.0-200606281455-win32.zip
>> I am also using Tomcat 5.5.16.
>> OS is Windows XP.
>> The tutorial I was following is here on Eclipse's web site,
>> http://www.eclipse.org/webtools/jst/components/ws/1.5/tutori als/BottomUpWebService/BottomUpWebService.html
>> Any help would be appreciated.
>> Seth
> Hi Seth
> This scenario gets run alot. Im surprised that this wouldnt work. So you
> were able to see the jsps? and you filled in the value on the method and
> selected invoke? Then the error appeared.
Re: The AXIS engine could not find a target service to invoke! targetService is Converter [message #178216 is a reply to message #178193] |
Tue, 29 August 2006 21:28 |
Larry Isaacs Messages: 1354 Registered: July 2009 |
The "real" error is in the Console Log:
SEVERE: Unable to find config file. Creating new servlet engine config
file: /WEB-INF/server-config.wsdd.
This message means that a default file is created which deploys no
services, hence the error in the Result window. For info about how this
file should have been created, see my post earlier to today for the
"Deployed Web Service disappears after changes in sources or Server
restart" thread [1]. The bottom line is that currently,
server-config.wsdd creation provided by the Web Services wizard only
works for Tomcat as the server, and only if "Run modules directly from
the workspace..." option is checked. This could be why
server-config.wsdd is missing in your case.
Larry
[1] http://dev.eclipse.org/newslists/news.eclipse.webtools/msg11 953.html
> straws here.
> Seth
>>> simple web service
>>> OS is Windows XP.
>>> Seth
>> Hi Seth
>> you were able to see the jsps? and you filled in the value on the
>> method and selected invoke? Then the error appeared.
Re: The AXIS engine could not find a target service to invoke! targetService is Converter [message #178276 is a reply to message #178216] |
Wed, 30 August 2006 14:37 |
Good eye. I saw that error about the server-config.wsdd file but didn't
really know what it meant.
I did have the "Run modules directly from the workspace..." unchecked.
For some reason I unchecked that because I was having trouble getting
regular web apps running. I went back and check it and did the tutorial
again and it worked.
Seth
> Cheers,
> Larry
>> all the JSPs. It deployed to Tomcat and loaded in the browser. I typed
>> in a Celsius value and got that error. I didn't do anything else.
>> file.
>> straws here.
>> Thanks,
>> Seth
>>>> simple web service
>>>> invoke! targetService is Converter.
>>>> OS is Windows XP.
>>>> Seth
>>> Hi Seth
Current Time: Fri Apr 26 03:49:27 GMT 2024
Powered by FUDForum. Page generated in 0.03101 seconds
