Howto change deploying path [message #171330] |
Thu, 15 June 2006 05:47  |
Hello, I have some problems deploying a war file on eclipse.
I checked the deployed dir and it was damaged because the war has deeply
nested dir structure and Windows Xp seems truncate some filenames with
very long pathname (more than 255 chars).
The same war works well if i deploy it on Tomcat directly.
Can I change the deploy path on Eclipse?
Can someone help me?
Mauro Gajetti
Re: Howto change deploying path [message #171456 is a reply to message #171350] |
Fri, 16 June 2006 04:48   |
Thanks a lot for the answer,
I would like to know what happens, if I choose to uncheck "Run modules
directly..", to my already deployed web apps on Tomcat,
will they be active when I start the server from Eclipse?
If I have one project with the same name on Eclipse will be overwrite on
Tomcat?
Can I see the web apps deployed on Tomcat and not present in Eclipse
Projects and can I choose to de/activate them?
Mauro Gajetti
Larry Isaacs ha scritto:
> There is already an enhancement request to make this configurable:
> https://bugs.eclipse.org/bugs/show_bug.cgi?id=107722
> In the meantime, if a short workspace path won't cut it, then your only
> alternative is to disable "Run modules directly from the workspace". You
> can double-click the server in the workspace to open the Tomcat server
> configuration editor. Uncheck "Run modules directly from the
> workspace..." option and save. This will cause the projects to be
> deployed to the Tomcat installation instead of the default location
> under your workspace. Be aware that WTP "owns" the Tomcat installation
> at that point, i.e. the Tomcat files under the Servers project in your
> workspace are the "masters". Install an additional Tomcat using the zip
> for this purpose if you don't want to mess with your original Tomcat
> installation.
> Cheers,
> Larry
>> deeply nested dir structure and Windows Xp seems truncate some
>> filenames with very long pathname (more than 255 chars).
>> Thanks,
>> Mauro Gajetti
Re: Howto change deploying path [message #171481 is a reply to message #171456] |
Fri, 16 June 2006 09:56  |
You ask a good question. I would recommend removing the projects first,
changing the option, then re-adding the projects. If you have already
deployed Eclipse projects to your currently installed Tomcat in a
fashion that is useful to you, I would recommend installing an
additional "test" Tomcat from a zip for use from within Eclipse. If the
two need to run at the same time, alter the port numbers for one of them.
With "Run modules..." unchecked, you will be able to see the standard
web applications that come with the installed Tomcat. If you go with a
"test" Tomcat, you can alter it's configuration to suit your testing
needs without disturbing your current Tomcat.
I haven't tested the scenario of changing this option while there are
projects added. I would assume that there would be problems. The
publishing code isn't aware that this kind of mode switch is possible in
the server, and is likely to behave badly in this situation. I have had
the idea in the past, and may implement in WTP 2.0, that the choice of
this behavior would be offered when the server is created, but wouldn't
be changeable afterward. You would have to create, or re-create, the
server to switch this option.
Larry
> Tomcat?
> Mauro Gajetti
>> only alternative is to disable "Run modules directly from the
>> workspace". You can double-click the server in the workspace to open
>> the Tomcat server configuration editor. Uncheck "Run modules directly
>> from the workspace..." option and save. This will cause the projects
>> to be deployed to the Tomcat installation instead of the default
>> location under your workspace. Be aware that WTP "owns" the Tomcat
>> installation at that point, i.e. the Tomcat files under the Servers
>> project in your workspace are the "masters". Install an additional
>> Tomcat using the zip for this purpose if you don't want to mess with
>> your original Tomcat installation.
>> Cheers,
>> Larry
>>> Thanks,
>>> Mauro Gajetti
FUDForum. Page generated in 1.24708 seconds
