Home » Modeling » Epsilon » EWL setting a profile/stereotype and trigger the wizard
EWL setting a profile/stereotype and trigger the wizard [message #15724] |
Tue, 21 April 2009 08:49 |
Originally posted by: friebenj.mail.upb.de
I have two (beginner) questions regarding EWL and its possibilities.
First I would like to create a wizard to apply a profile to a package of
a selected class (if not already applied). Afterwards a stereotype of
this profile should be attached to the selected class and a new property
should be set.
The epsilon book contains an example for attaching a stereotype, but I
can not find a way to set the profile first and to assign change/set
properties later.
Second - exists the possibility to execute an EWL wizard not only from
the wizards popup menu, but also from self coded menu actions or other
events?
Any help welcome!
Jens Frieben
Re: EWL setting a profile/stereotype and trigger the wizard [message #15741 is a reply to message #15724] |
Tue, 21 April 2009 09:09 |
Dimitrios Kolovos Messages: 1776 Registered: July 2009 |
Hi Jens,
Jens Frieben wrote:
> Hello,
> should be set.
> properties later.
Please have a look at
http://dev.eclipse.org/mhonarc/newsLists/news.eclipse.epsilo n/msg00111.html
for an example of applying a UML profile programmatically with Epsilon.
In this example, the profile is known and loaded in the form of an
additional model (Profile). In the case of EWL, only one model is
available by default (the one currently edited) so we'll need to load
and put the profile model in the context using a Tool (see
http://www.eclipse.org/gmt/epsilon/doc/EpsilonTools.pdf) at runtime.
If this all sounds terribly complicated, please post an enhancement
request in the bugzilla and I'll try to come up with an working example
as soon as possible.
> events?
Sure. The org.eclipse.epsilon.ewl.emf plugin in the SVN provides a good
example of doing so.
> Any help welcome!
> Jens Frieben
Dimitris
Re: EWL setting a profile/stereotype and trigger the wizard [message #16209 is a reply to message #15741] |
Wed, 22 April 2009 10:50 |
Thanks for you quick reply.
I am currently trying to get such a 'Tool' to work for loading the new
profile. I will of course post a successful implementation here.
Dimitris Kolovos schrieb:
> Hi Jens,
> Jens Frieben wrote:
>> Hello,
>> of a selected class (if not already applied). Afterwards a stereotype
>> of this profile should be attached to the selected class and a new
>> property should be set.
>> properties later.
>> events?
>> Any help welcome!
>> Thanks,
>> Jens Frieben
> Cheers,
> Dimitris
Re: EWL setting a profile/stereotype and trigger the wizard [message #16276 is a reply to message #16209] |
Fri, 24 April 2009 12:35 |
Thanks Jens. Looking forward to hearing more on this.
Dimitris
>> Hi Jens,
>> Jens Frieben wrote:
>>> Hello,
>>> I can not find a way to set the profile first and to assign
>>> change/set properties later.
>> Epsilon. In this example, the profile is known and loaded in the form
>> of an additional model (Profile). In the case of EWL, only one model
>> is available by default (the one currently edited) so we'll need to
>> load and put the profile model in the context using a Tool (see
>> example as soon as possible.
>>> from the wizards popup menu, but also from self coded menu actions or
>>> other events?
>> good example of doing so.
>>> Any help welcome!
>>> Thanks,
>>> Jens Frieben
>> Cheers,
>> Dimitris
Re: EWL setting a profile/stereotype and trigger the wizard [message #566868 is a reply to message #15724] |
Hi Jens,
Jens Frieben wrote:
> Hello,
> should be set.
> properties later.
> events?
> Any help welcome!
> Jens Frieben
Dimitris
Re: EWL setting a profile/stereotype and trigger the wizard [message #567013 is a reply to message #15741] |
> Hi Jens,
> Jens Frieben wrote:
>> Hello,
>> properties later.
>> events?
>> Any help welcome!
>> Thanks,
>> Jens Frieben
> Cheers,
> Dimitris
Re: EWL setting a profile/stereotype and trigger the wizard [message #567096 is a reply to message #16209] |
Dimitris
>> Hi Jens,
>> Jens Frieben wrote:
>>> Hello,
>>> other events?
>>> Any help welcome!
>>> Thanks,
>>> Jens Frieben
>> Cheers,
>> Dimitris
Current Time: Sat Apr 27 03:33:54 GMT 2024
Powered by FUDForum. Page generated in 0.03921 seconds
