Can't upgrade to BIRT Runtime 4.3 [message #1066918] |
Fri, 05 July 2013 07:15 |
Juliane Harbarth Messages: 21 Registered: July 2009 |
Junior Member |
Good morning,
we used to include a BIRT runtime as part of our SOA environment and this worked fine for a long time (for something like four years now). The last time we upgraded to a higher BIRT runtime we went to:
viewerVersion/engineVersion = "2.6.1";
For previous upgrades, I just took the birt.war from the respective download and with this replaced our previous birt.war in the build-process that includes the reporting facilities into the overall system. Since this went well the last times, I intended to proceed like this for (232->261) but this proves impossible.
The first problem is that on the download page (http://download.eclipse.org/birt/downloads) there are now two BIRT runtimes, i.e. birt-runtime-4_3_0.zip and birt-runtime-osgi-4_3_0.zip. After looking at the birt.war's, I decided for the one from birt-runtime-osgi-4_3_0.zip, since the other one does not contain \WEB-INF\platform\ which our previously included birt.war did. We also need this because our building process adds to its 'plugins' subfolder.
When utilizing the built result in our environment (which is basically Apache Tomcat/7.0.29) by running a report this resulted in
Fatal error occurred when try to startup report engine.
org.eclipse.birt.report.exception.ViewerException: Fatal error occurred when try to startup report engine.
at org.eclipse.birt.report.service.ReportEngineService.setEngineContext(ReportEngineService.java:342)
complete stack trace is added at the end.
To make sure this is not caused by our additions to the downloaded birt.war, I tried it with the original birt.war 4.3 also with the same result. To make sure this is not caused by the way we call it in our environment, I called the birt webapp directly from the browser and this yielded 'BIRT viewer has been installed', but 'View Example' gave me the same error.
So the error must be caused by the fact that the 4.3 birt.war I took does not fit into the environment I deployed it into. Next I'll try with a raw Tomcat 7.0.29. Googling with the above error gave me lots of ideas, but these were rather diverse. Can anybody give me a hint about what I am doing wrong, it might be a very fundamental thing having to do with this OSGi-fication? Does the error message ring a bell for somebody?
Thank you very much & regards,
Juliane.
- Fatal error occurred when try to startup report engine.
at org.eclipse.birt.report.service.BirtViewerReportService.setContext(BirtViewerReportService.java:1022)
at org.eclipse.birt.report.servlet.ViewerServlet.__getContext(ViewerServlet.java:148)
at org.eclipse.birt.report.servlet.BirtSoapMessageDispatcherServlet.doGet(BirtSoapMessageDispatcherServlet.java:151)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:621)
at org.apache.axis.transport.http.AxisServletBase.service(AxisServletBase.java:327)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:722)
at org.eclipse.birt.report.servlet.BirtSoapMessageDispatcherServlet.service(BirtSoapMessageDispatcherServlet.java:122)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:305)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:210)
at org.eclipse.birt.report.filter.ViewerFilter.doFilter(ViewerFilter.java:68)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:243)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:225)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:123)
at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:472)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:168)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:98)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:118)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:407)
at org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1001)
at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:585)
at org.apache.tomcat.util.net.JIoEndpoint$SocketProcessor.run(JIoEndpoint.java:310)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615)
at java.lang.Thread.run(Thread.java:724)
Re: Can't upgrade to BIRT Runtime 4.3 [message #1067052 is a reply to message #1066918] |
Fri, 05 July 2013 15:23 |
Yes. There are now two versions of the runtime. In 3.7.0, the runtime switched to a POJO runtime. This caused a problem for some people, so in 3.7.2, the OSGi option was added back as a separate option. This is why there are two. As for the issue you're having, I'm downloading the OSGi runtime to check it out. I've got Tomcat 7.0.41 that I'll try it on. I'll let you know if I have any issues.
Michael
Developer Evangelist, Silanis
FUDForum. Page generated in 0.03511 seconds
