IWAB0523E Error moving resource: null [message #1059308] |
Fri, 17 May 2013 13:30 |
Asha Honrao Messages: 1 Registered: May 2013 |
Junior Member |
Hi There,
Am trying to generate java proxy using WSDL (present at a server) using WS client in Eclipse 3.4.1
But encountering below error :
Detailsed error is:
at org.eclipse.wst.command.internal.env.common.FileResourceUtils.makeFolderPathAtLocation(FileResourceUtils.java:790)
at org.eclipse.wst.command.internal.env.common.FileResourceUtils.makeFolderPathAtLocation(FileResourceUtils.java:833)
at org.eclipse.wst.command.internal.env.common.FileResourceUtils.createFileAtLocation(FileResourceUtils.java:765)
at org.eclipse.jst.ws.internal.axis.consumption.core.command.WSDL2JavaCommand.moveGeneratedFiles(WSDL2JavaCommand.java:327)
at org.eclipse.jst.ws.internal.axis.consumption.core.command.WSDL2JavaCommand.execute(WSDL2JavaCommand.java:250)
at org.eclipse.jst.ws.internal.axis.consumption.ui.task.ClientCodeGenOperation$ClientWSModifyOperation.execute(ClientCodeGenOperation.java:102)
at org.eclipse.jst.ws.internal.axis.consumption.ui.task.ClientCodeGenOperation.execute(ClientCodeGenOperation.java:64)
at org.eclipse.wst.command.internal.env.core.fragment.CommandFragmentEngine.runCommand(CommandFragmentEngine.java:419)
at org.eclipse.wst.command.internal.env.core.fragment.CommandFragmentEngine.visitTop(CommandFragmentEngine.java:359)
at org.eclipse.wst.command.internal.env.core.fragment.CommandFragmentEngine.moveForwardToNextStop(CommandFragmentEngine.java:254)
at org.eclipse.wst.command.internal.env.ui.widgets.SimpleCommandEngineManager$6.run(SimpleCommandEngineManager.java:294)
at org.eclipse.jface.operation.ModalContext.runInCurrentThread(ModalContext.java:458)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.java:366)
at org.eclipse.jface.wizard.WizardDialog.run(WizardDialog.java:934)
at org.eclipse.wst.command.internal.env.ui.widgets.SimpleCommandEngineManager.runForwardToNextStop(SimpleCommandEngineManager.java:264)
at org.eclipse.wst.command.internal.env.ui.widgets.WizardPageManager.runForwardToNextStop(WizardPageManager.java:91)
at org.eclipse.wst.command.internal.env.ui.widgets.WizardPageManager.performFinish(WizardPageManager.java:262)
at org.eclipse.wst.command.internal.env.ui.widgets.DynamicWizard.performFinish(DynamicWizard.java:382)
at org.eclipse.jface.wizard.WizardDialog.finishPressed(WizardDialog.java:742)
at org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDialog.java:373)
at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.java:624)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:228)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1003)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:3823)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3422)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:825)
at org.eclipse.jface.window.Window.open(Window.java:801)
at org.eclipse.ui.internal.handlers.WizardHandler$New.executeHandler(WizardHandler.java:253)
at org.eclipse.ui.internal.handlers.WizardHandler.execute(WizardHandler.java:273)
at org.eclipse.ui.internal.handlers.HandlerProxy.execute(HandlerProxy.java:281)
at org.eclipse.core.commands.Command.executeWithChecks(Command.java:476)
at org.eclipse.core.commands.ParameterizedCommand.executeWithChecks(ParameterizedCommand.java:508)
at org.eclipse.ui.internal.handlers.HandlerService.executeCommand(HandlerService.java:169)
at org.eclipse.ui.internal.handlers.SlaveHandlerService.executeCommand(SlaveHandlerService.java:247)
at org.eclipse.ui.internal.actions.CommandAction.runWithEvent(CommandAction.java:157)
at org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionItem.java:583)
at org.eclipse.jface.action.ActionContributionItem.access$2(ActionContributionItem.java:500)
at org.eclipse.jface.action.ActionContributionItem$5.handleEvent(ActionContributionItem.java:411)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2382)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2346)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2198)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:493)
at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:288)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:488)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:113)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:193)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:386)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:549)
Here am not getting whetehr the wizard is unable to locate the WSDL(provided a http URL for WSDL) or it is able to createand copy the generated files at some location.
Note: Wizard does not ask for the specific location to select under the project.
Appreciate all you help on this topic. Thanks.
FUDForum. Page generated in 0.03754 seconds
