Re: Unable to eclipse due to java was started but returned exit code=14 [message #1028690 is a reply to message #1028388] |
Thu, 28 March 2013 15:59 |
On 3/28/2013 9:50 AM, SM Lim wrote:
> Hi all,
> I was tried to run the eclipse from my win 7 64 bit system. I have installed from "adt-bundle-windows-x86_64-20130219". However, when run eclipse.exe, the screen has prompt for error message of java was started but returned exit code=14.
> I am attached the error output.
> Anyone please help me.
So, let me get this straight:
You're running a 64-bit Eclipse on a 64 bit-capable OS, but using a
32-bit JRE?
Re: Unable to eclipse due to java was started but returned exit code=14 [message #1067169 is a reply to message #1067156] |
Sun, 07 July 2013 03:59 |
On 07/06/2013 05:36 PM, Erwin De Bock wrote:
> can anyone help me,
> i get the error code 14 and dpo not find the solution
> i m running windows 7 professional 64 bit
> and i tried the next ini, but it doesn t work :
> -startup
> plugins/org.eclipse.equinox.launcher_1.3.0.v20130327-1440.jar
> --launcher.library
> plugins/org.eclipse.equinox.launcher.win32.win32.x86_64_1.1.200.v20130521-0416
> -product
> org.eclipse.epp.package.reporting.product
> --launcher.defaultAction
> openFile
> --launcher.XXMaxPermSize
> 256M
> -showsplash
> org.eclipse.platform
> 256m
> openFile
> D:\Erwin\temp\eclipse-reporting-kepler-R-win32-x86_64\eclipse\jre\bin\javaw.exe
> --launcher.appendVmargs
> -vmargs
> -Dosgi.requiredJavaVersion=1.6
> -Xms40m
> -Xmx512m
You're running a 64-bit Eclipse; ensure that you're also running a
64-bit JRE. One way to do this is to place the following in eclipse.ini
before -vmargs:
-vm
<path-to-64-bit-JRE>
Unless Kepler has changed the syntax, you failed to do this (forgot the
-vm).
FUDForum. Page generated in 0.08601 seconds
