Home » Eclipse Projects » EclipseLink » @AttributeOverride ignored with @Embedded
@AttributeOverride ignored with @Embedded [message #1007091] Mon, 04 February 2013 07:13 Go to next message
Hi there,
we are using eclipse link 2.4 and we are having some issues on @AttributeOverride that seems to be ignored when we are referring to an @Embedded reference.
Here our scenario:
Person person
|-- Address myAddress
|-- Address secondaryAddress
where:
Address
|-- Zip myZip
|-- Zip mySecondaryZip
|-- String name
Zip
|-- Country myCountry
|-- String zipCode
Country
|-- String description
Address, Zip and Country classes are declared as @Embeddable(). Person is an @Entity.
myAddress has the following JPA annotations:
    @Embedded()
@AttributeOverrides({ @AttributeOverride(column = @Column(name = "myaddress_name"), name = "name"),
        @AttributeOverride(column = @Column(name = "myaddress_myzip_zipcode"), name = "myZip.zipCode"),
        @AttributeOverride(column = @Column(name = "myaddress_myzip_mycountry_description"), name = "myZip.myCountry.description"),
        @AttributeOverride(column = @Column(name = "myaddress_mysecondaryzip_zipcode"), name = "mySecondaryZip.zipCode"),
        @AttributeOverride(column = @Column(name = "myaddress_mysecondaryzip_mycountry_description"), name = "mySecondaryZip.myCountry.description") })
private Address myAddress = null;
Using eclipseLink and postgresql the columns:
are not created in person table. The others are correctly created. We are using JPA 2.0 and postgresql 9.2. Why does it happen ? Am I missing something obvious ?
Is there a problem with a three level-nested path ?
Re: @AttributeOverride ignored with @Embedded [message #1007354 is a reply to message #1007091] Tue, 05 February 2013 10:39 Go to previous message
Seems like it could be a bug, please log a bug with a test case.
Previous Topic:Where to download MOXy 2.2 ?
Next Topic:dbws utils generated war file gives error : _dbws.DBWSProvider is not available
Current Time: Sun Jul 13 12:02:49 EDT 2025
Powered by FUDForum. Page generated in 0.04160 seconds
