Re: NoClassDefFoundError on SpringBlueprintContainer when installing cxf-api [message #990247 is a reply to message #989985] |
Tue, 11 December 2012 15:24 |
Glyn Normington Messages: 1222 Registered: July 2009 |
It's normal for two instances of Gemini Blueprint to be installed. One goes in the kernel region (from plugins/) and the other in the user region via the kernel deployer. The two shouldn't interfere with each other unless you have changed the user region properties file (in configuration/). The bundles you drop into pickup/ are deployed into the user region and should collaborate with the Gemini Blueprint in the user region.
I agree the behaviour you are seeing is pretty bizarre though. The CXF API bundle doesn't contain any embedded JARs does it? (Some CXF "uber bundles" do contain embedded JARs and can lead to surprising behaviour.)
[Updated on: Tue, 11 December 2012 15:25] Report message to a moderator
FUDForum. Page generated in 0.03598 seconds
