Home » Eclipse Projects » Buckminster » The import org.eclipse.swt cannot be resolved
| Re: The import org.eclipse.swt cannot be resolved [message #989248 is a reply to message #989114] |
Wed, 05 December 2012 05:53   |
Lorenzo Bettini Messages: 1139 Registered: July 2009 |
On 12/04/2012 05:40 PM, Eike Stepper wrote:
> Am 04.12.2012 11:38, schrieb Lorenzo Bettini:
>> On 12/04/2012 08:43 AM, Eike Stepper wrote:
>>> Hi,
>>> Since November 28 our Hudson (linux) build keeps failing because SWT can
>>> not be resolved:
>>> https://hudson.eclipse.org/hudson/job/emf-cdo-integration
>>> The target platform only contains a
>>> org.eclipse.swt.win32.win32.x86_64_3.8.1.v3834e.jar
>>> <https://hudson.eclipse.org/hudson/job/emf-cdo-integration/ws/result/tp/plugins/org.eclipse.swt.win32.win32.x86_64_3.8.1.v3834e.jar>
>>> fragment:
>>> That might explain why the build works at home on Windows. But where
>>> have the other platform fragments gone? Any ideas?
>> Hi
>> for curiosity (I'm recently taking a look at projects which use
>> buckminster to get inspiration ;) I took a look here
>> http://git.eclipse.org/c/cdo/cdo.git/tree/plugins/org.eclipse.emf.cdo.releng/build.cquery
>> I don't know if that is the cause, but you skip some gtk components from
>> swt and equinox ...
> Hmm, it doesn't look like the cause to me. I'm only excluding source
> components and fragments for unneeded platforms. And I've not touched
> that file for ages. Nevertheless I'm trying a build with those lines
> commented out...
The error seems different now... it looks like it can't find
javax.annotations...
https://hudson.eclipse.org/hudson/job/emf-cdo-integration/2554/console
Lorenzo Bettini, PhD in Computer Science, DI, Univ. Torino
ICQ# lbetto, 16080134 (GNU/Linux User # 158233)
HOME: http://www.lorenzobettini.it MUSIC: http://www.purplesucker.com
http://www.myspace.com/supertrouperabba
BLOGS: http://tronprog.blogspot.com http://longlivemusic.blogspot.com
http://www.gnu.org/software/src-highlite
http://www.gnu.org/software/gengetopt
http://www.gnu.org/software/gengen http://doublecpp.sourceforge.net
| Re: The import org.eclipse.swt cannot be resolved [message #989359 is a reply to message #989312] |
Wed, 05 December 2012 15:12   |
On 12/05/2012 04:51 PM, Eike Stepper wrote:
> Am 05.12.2012 11:53, schrieb Lorenzo Bettini:
> Yeah, that was an attempt to use fixed os/ws/arch parameters. It
> obviously failed. And it couldn't be an end solution because our build
> used to produce example products for multiple platforms ;-(
But you don't use
<cq:property key="target.arch" value="*"/>
<cq:property key="target.os" value="*"/>
<cq:property key="target.ws" value="*"/>
in your cquery, do you?
probably it's in a properties file, I guess...
I don't know whether your problem is related to this, but on 28
November, Thomas released a fix for this bug
https://bugs.eclipse.org/bugs/show_bug.cgi?id=395070
and it looks like your job stopped working on that date...
but I don't know the internal details, Thomas will have to say something :)
cheers
Lorenzo
| Re: The import org.eclipse.swt cannot be resolved [message #989466 is a reply to message #989442] |
Thu, 06 December 2012 05:36   |
Eike Stepper Messages: 5177 Registered: July 2009 |
Am 06.12.2012 10:14, schrieb Thomas Hallgren:
> On 2012-12-06 09:42, Eike Stepper wrote:
>> Am 06.12.2012 09:00, schrieb Thomas Hallgren:
>>> 3. Did any of this change recently? What happened on November 28?
>> No, the last commit to our maintenance branch was almost exactly 1 month
>> *before* the failures started (Nov. 28).
> This issue really displays all the traits of a regression in the build system. You tested with:
> org.eclipse.buckminster.site.eclipse.headless_1.5.0.v20121118-2330.zip
> and that displayed the same problems. Are you sure that this is the one that your build was using previously? I guess
> the answer is yes, you always pick the latest from our headless site. But just to be sure, could you try with the
> version before that, i.e.
> http://www.eclipse.org/downloads/download.php?file=/tools/buckminster/archivedsites-4.2/org.eclipse.buckminster.site.eclipse.headless_1.5.0.v20121007-1625.zip
Wow, with that version it works, too: https://hudson.eclipse.org/hudson/job/emf-cdo-integration/2565/console
Cheers
/Eike
http://www.esc-net.de
> or if there's a chance to set up a sandbox where I could try and save you the time of doing it, that would be fine
> too. It just seems so odd that your build suddenly require parameters that it didn't use to have even though nothing
> changed.
> - thomas
| Re: The import org.eclipse.swt cannot be resolved [message #989472 is a reply to message #989466] |
Thu, 06 December 2012 06:07   |
Thomas Hallgren Messages: 3168 Registered: July 2009 |
>> one that your build was using previously? I guess the answer is yes,
>> sure, could you try with the version before that, i.e.
OK. So that suggests a regression between our 20121007 and 20121118
versions that somehow affects how properties are passed from the mspec
during import. I'll investigate that.
Thanks a lot for investing time helping with this Eike. It would be hard
to track things down if you didn't.
- thomas
| Re: The import org.eclipse.swt cannot be resolved [message #989735 is a reply to message #989424] |
Fri, 07 December 2012 08:12  |
On 12/06/2012 09:00 AM, Thomas Hallgren wrote:
> One time should be enough. The properties passed on the command line are
> merged with the ones from the cquery and the rmap. The mspec ones should
> be passed to unless you first resolve using the cquery and then, as a
> separate step perform the materialization using your mspec and a bom file.
Hi Thomas
concerning the merging of properties I noted a behavior which I do not
know whether it's the one expected: I've set up for one of my projects a
cquery to materialize all the projects in the workspace
http://emf-components.eclipselabs.org.codespot.com/git/releng/it.rcpvision.emf.components.buckminster/remote/web-build.cquery
the URL is thought to be opened in the IDE and it clones the git repo,
materialize target platform and all projects in the workspace.
In the rmap I have some properties, like git.clone.dest, that I can
redefine, for instance, in a Jenkins job when calling buckminster
headlessly. The default value for such properties is in the rmap.
Everything works.
Now, if I try to put a default value for these properties in the cquery,
then the values passed on the command line are ignored...
is it the expected behavior (it's not a problem for my context)?
Otherwise it might be somehow related to Eike's problem?
cheers
Lorenzo
Current Time: Tue Jun 18 17:18:03 EDT 2013
Powered by FUDForum. Page generated in 0.01900 seconds
