Home » Eclipse Projects » GEF » Compound Command issues
Compound Command issues [message #142652] |
Tue, 13 July 2004 16:08  |
Originally posted by: brian.fernandes.codito.com
Hi Guys,
I've recently been experimenting with multiple selection in my diagram; and
I'm facing a few issues.
I have models : Diagram, Lane, Box and Child.
Diagram is the main root model.
Lane exists within Diagram.
Box can only exist within Lane
Child can only exist within Box.
Now, if you try to move an existing Box into another Box, the Box's Layout
EditPolicy detects this in the createAddCommand and returns a null command.
No command is executed and therefore; you won't be able to move a Box into
another Box.
Now, if you select a Box(A) AND a Child (which exists in another Box(B) )
and attempt to move this into another Box(C), the createAddCommand will
return null for attempting to move A into C. However, moving the Child into
C is allowed and an (add) command is created.
The users chosen operation partially executes. Since the compound command
can execute, the Box A is orphaned from it's parent lane, but it is NOT
added to C (- the add command was not created, which is correct). So A
disappears from the diagram. The Child however, is added to C. I would like
"all or nothing" either all commands are executed - or none are. With what
is happening now, I'm losing A from the diagram AND a partial command is
being executed.
How do I implement an "all or nothing" approach ? Should I place the model
constrint checks elsewhere ? in getTargetEditPart for instance ? Or should I
override ConstrainedLayoutEditPolicy#getAddCommand and return null if any of
the commands in the compund command are null or unexecutable ?
Or am I barking up the wrong tree ?
Thanks in advance,
Brian.
Re: Compound Command issues [message #142767 is a reply to message #142652] |
Thu, 15 July 2004 02:58   |
Originally posted by: eostroukhov.hotmail.com
Simply return UnexecutableCommand.INSTANCE. Returning null signals that the
edit part does nothing in respond to request while the
UnexecutableCommand.INSTANCE signals that the operation cannot be performed.
"Brian Fernandes" <brian.fernandes@codito.com> wrote in message
news:cd1f3n$u2p$1@eclipse.org...
> Hi Guys,
and
command.
> another Box.
into
like
> being executed.
I
of
> Thanks in advance,
> Brian.
Re: Compound Command issues [message #142788 is a reply to message #142767] |
Thu, 15 July 2004 06:20  |
"Eugene Ostroukhov" <eostroukhov@hotmail.com> wrote in message
news:cd59t8$qes$1@eclipse.org...
the
performed.
thanks Eugene.
I had a solution worked out by overriding getTargetEditPart in the layout
EditPolicies of the concerened EditParts; however, this seems to be a much
cleaner & clearer approach.
Brian.
> > Hi Guys,
> and
Layout
> command.
into
> > another Box.
Box(B) )
> into
command
> like
what
> > being executed.
model
should
> I
any
> of
> > Thanks in advance,
> > Brian.
Current Time: Thu Jul 03 11:07:49 EDT 2025
Powered by FUDForum. Page generated in 0.04763 seconds
