no output on stdout in console [message #141663] |
Wed, 23 March 2005 14:50 |
Originally posted by: mwisse.hs-harz.de
Hallo,
I am a beginner with C development under eclipse.
I wrote a small C-program for the console, which should display some
values in a loop. These values should be given out on stdout with
printf().
The console stays empty, if I use an endless loop. If I end the loop after
some cycles and exit the program, then the output values are displayed
when the program ends.
If I print with fprintf on stderr, then console is filled immediatly with
output.
It could be a matter with the underlying OS (linux), but if I start the
program in a terminal, it displays outputs on stdout correct.
I use eclipse 2.1.3 with cdt 1.2.1.
Regards und thanks for advice
Michael
FUDForum. Page generated in 0.03057 seconds
