Home » Language IDEs » ServerTools (WTP) » context.xml
Re: context.xml [message #141329 is a reply to message #141277] |
Thu, 29 September 2005 15:27 |
Larry Isaacs Messages: 1354 Registered: July 2009 |
Zohar,
On the todo list is to improve the error handing if there is a problem
reading the context.xml. Currently, there is no error reported and
including the context information is skipped. The XML you show below
looks fine (works copy & pasted in a webapp in my workspace). The one
mysterious way I am aware of to cause this problem is to be running
Eclipse with a 1.4.x JRE or JDK and have a Byte-Order-Mark at the
beginning of the file. The Crimson XML parser obtained from the 1.4.x
JRE or JDK doesn't handle this BOM and erroneously considers it an error.
If this is the case, you can open the context.xml with the Text Editor.
Set the encoding to be US-ASCII or ISO-8859-1 and three funny
characters should appear at the beginning of the file, which can be
deleted. Then set the encoding back to what it was. Hopefully that is
the problem.
Larry
Zohar wrote:
> Hello,
> I know this has been asked a thousand times before, but I still seem to have
> problems with my servlet's context.xml .
> I created a context.xml file in my project's WebContent/META-INF directory.
> In that xml file I've put something like:
> <Context>
> <Parameter name="P1" value="bla"/>
> <Parameter name="P2" value="bli"/>
> <Parameter name="P3" value="blo"/>
> </Context>
> but in my servlet's init method, the configuration I get contains no
> parameters.
> I've tried do "publish" manually, deploy/undeploy the module.
> I'm using tomcat 5.5 on Win XP with eclipse 3.1 and WTP 0.7 .
> What may be the cause of this?
> Zohar.
Re: context.xml [message #142566 is a reply to message #141329] |
Thu, 06 October 2005 12:49 |
Zohar Amir Messages: 419 Registered: July 2009 |
I checked and there is no BOM in the beginning? any other possible causes
for this? can I check some logs for this somewhere?
"Larry Isaacs" <Larry.Isaacs@sas.com> wrote in message
news:dhh145$2m6$1@news.eclipse.org...
> Zohar,
> beginning of the file. The Crimson XML parser obtained from the 1.4.x JRE
> Set the encoding to be US-ASCII or ISO-8859-1 and three funny characters
> should appear at the beginning of the file, which can be deleted. Then
> set the encoding back to what it was. Hopefully that is the problem.
> Cheers,
> Larry
> Zohar wrote:
>> Hello,
>> have problems with my servlet's context.xml .
>> directory. In that xml file I've put something like:
>> <?xml version="1.0" encoding="UTF-8"?>
>> <Context>
>> </Context>
>> parameters.
>> Thanks,
>> Zohar.
Re: context.xml [message #143089 is a reply to message #142566] |
Tue, 11 October 2005 13:06 |
Sorry for the delayed response. I was away on vacation. Did you
discover the problem, or is it still a mystery? Out side of the BOM,
I'm only aware of XML syntax errors causing this, which I'm sure you've
already checked.
Larry
>>Zohar,
>>Cheers,
>>Larry
>>Zohar wrote:
>>>Hello,
>>><Context>
>>></Context>
>>>parameters.
>>>Thanks,
>>>Zohar.
Re: context.xml [message #143135 is a reply to message #143089] |
Tue, 11 October 2005 16:45 |
Thanks for the reply (hope you had a nice vacation).
Haven't nailed this yet...
The file is valid (used XML Spy to check it).
No logs to look at?
news:digdcj$8kp$1@news.eclipse.org...
> Sorry for the delayed response. I was away on vacation. Did you discover
> the problem, or is it still a mystery? Out side of the BOM, I'm only
> aware of XML syntax errors causing this, which I'm sure you've already
> checked.
> Larry
>>>Zohar,
>>>Cheers,
>>>Larry
>>>Zohar wrote:
>>>>Hello,
>>>><Context>
>>>></Context>
>>>>parameters.
>>>>Thanks,
>>>>Zohar.
Re: context.xml [message #143153 is a reply to message #143135] |
Tue, 11 October 2005 17:38 |
To this point, I have been assuming that "in my servlet's init method,
the configuration I get contains no parameters" means that the <Context>
element in the server.xml under
".metadata\.plugins\org.eclipse.wst.server.core\tmp0\conf" doesn't
include the <Parameter> child elements. Is this the case, or is it that
your servlet just doesn't see them? If the server.xml includes the
parameter elements, what does your init method look like?
Larry
> No logs to look at?
>>checked.
>>Larry
>>>>Zohar,
>>>>Cheers,
>>>>Larry
>>>>Zohar wrote:
>>>>>Hello,
>>>>><Context>
>>>>></Context>
>>>>>parameters.
>>>>>Thanks,
>>>>>Zohar.
Re: context.xml [message #144016 is a reply to message #143153] |
Sun, 16 October 2005 12:34 |
In my servlet I have:
-----------------------------8<------------------------------------------
public void init(ServletConfig config) throws ServletException {
Enumeration paramNames = config.getInitParameterNames();
while(paramNames.hasMoreElements()){
String sCurrElemName = (String) paramNames.nextElement();
String sCurrElemValue = config.getInitParameter(sCurrElemName);
System.out.println(sCurrElemName+"="+sCurrElemValue);
Nothing gets printed, and when running in debug mode I can see that the
enumeration is empty.
I deleted the project and recreated it, but it didn't help.
news:digta3$2fo$1@news.eclipse.org...
> To this point, I have been assuming that "in my servlet's init method, the
> ".metadata\.plugins\org.eclipse.wst.server.core\tmp0\conf" doesn't include
> the <Parameter> child elements. Is this the case, or is it that your
> servlet just doesn't see them? If the server.xml includes the parameter
> Larry
>> No logs to look at?
>>>discover the problem, or is it still a mystery? Out side of the BOM, I'm
>>>already checked.
>>>Larry
>>>>causes for this? can I check some logs for this somewhere?
>>>>>Zohar,
>>>>>error.
>>>>>the problem.
>>>>>Cheers,
>>>>>Larry
>>>>>Zohar wrote:
>>>>>>Hello,
>>>>>>to have problems with my servlet's context.xml .
>>>>>><Context>
>>>>>></Context>
>>>>>>parameters.
>>>>>>Thanks,
>>>>>>Zohar.
Re: context.xml [message #144081 is a reply to message #143153] |
Mon, 17 October 2005 07:46 |
I now have one project where the context.xml's content is passed to the
servlet's init method, and another where it doesn't... What differences
should I look for between the two?
> Larry
>> No logs to look at?
>>>already checked.
>>>Larry
>>>>>Zohar,
>>>>>error.
>>>>>the problem.
>>>>>Cheers,
>>>>>Larry
>>>>>Zohar wrote:
>>>>>>Hello,
>>>>>><Context>
>>>>>></Context>
>>>>>>parameters.
>>>>>>Thanks,
>>>>>>Zohar.
Re: context.xml [message #144090 is a reply to message #143153] |
Mon, 17 October 2005 07:59 |
I looked at
<workspace> \.metadata\.plugins\org.eclipse.wst.server.core\tmp0\conf\se rver.xml
and it contains a "Context" element for the problematic context with all of
the "parameter" subelements in it.
> Larry
>> No logs to look at?
>>>already checked.
>>>Larry
>>>>>Zohar,
>>>>>error.
>>>>>the problem.
>>>>>Cheers,
>>>>>Larry
>>>>>Zohar wrote:
>>>>>>Hello,
>>>>>><Context>
>>>>>></Context>
>>>>>>parameters.
>>>>>>Thanks,
>>>>>>Zohar.
Re: context.xml [message #144140 is a reply to message #144016] |
Mon, 17 October 2005 14:24 |
Your parameters will appear as if your web.xml contained the equivalent
context parameters. To read them, I believe you want:
Enumeration paramNames = getServletContext().getInitParameterNames();
You are currently trying to the servlet's init parameters.
Larry
>>Larry
>>>No logs to look at?
>>>>already checked.
>>>>Larry
>>>>>>Zohar,
>>>>>>error.
>>>>>>the problem.
>>>>>>Cheers,
>>>>>>Larry
>>>>>>Zohar wrote:
>>>>>>>Hello,
>>>>>>><Context>
>>>>>>></Context>
>>>>>>>parameters.
>>>>>>>Thanks,
>>>>>>>Zohar.
Re: context.xml [message #144385 is a reply to message #144140] |
Wed, 19 October 2005 08:21 |
I'm a bit confused then (this may be a servlet / tomcat general question).
What are the options of configuring my servlet and how do I do this with
WTP? I want these parameters to be set by the servlet's deployer, not the
writer (me).
I read getServletContext's javadoc and it says that it is the same object as
the one passed to init - so what's the difference?
Thanks again,
Zohar.
news:dj0c6k$k46$1@news.eclipse.org...
> Larry
>>>".metadata\.plugins\org.eclipse.wst.server.core\tmp0\conf " doesn't
>>>Larry
>>>>No logs to look at?
>>>>>already checked.
>>>>>Larry
>>>>>>>Zohar,
>>>>>>>problem reading the context.xml. Currently, there is no error
>>>>>>>reported and including the context information is skipped. The XML
>>>>>>>you show below
>>>>>>>one mysterious way I am aware of to cause this problem is to be
>>>>>>>running Eclipse with a 1.4.x JRE or JDK and have a Byte-Order-Mark at
>>>>>>>the beginning of the file. The Crimson XML parser obtained from the
>>>>>>>1.4.x JRE or JDK doesn't handle this BOM and erroneously considers it
>>>>>>>an error.
>>>>>>>Editor. Set the encoding to be US-ASCII or ISO-8859-1 and three funny
>>>>>>>is the problem.
>>>>>>>Cheers,
>>>>>>>Larry
>>>>>>>Zohar wrote:
>>>>>>>>Hello,
>>>>>>>><Context>
>>>>>>>></Context>
>>>>>>>>parameters.
>>>>>>>>Thanks,
>>>>>>>>Zohar.
Re: context.xml [message #144438 is a reply to message #144385] |
Wed, 19 October 2005 14:29 |
In web.xml you can have:
<web-app>
<context-param>
<param-name>P1</param-name>
<param-value>bla</param-value>
</context-param>
<servlet>
<servlet-name>SomeServlet</servlet-name>
<servlet-class>some.pkg.SomeServlet</servlet-class>
<init-param>
<param-name>P2</param-name>
<param-value>bli</param-value>
</init-param>
</servlet>
</web-app>
Using "getServletContext().getInitParameterNames()" will give you "P1",
where your "config.getInitParameterNames()" will give you "P2". As a
bonus feature of Tomcat, your <Parameter> elements in the context.xml
create the equivalent of <context-parameter> elements found in the
web.xml. Thus, you can specify them without modifying the webapp's
web.xml. The only problem is that your code below is trying to read
<init-param> info instead of <context-param> info, and as a result, is
unable to see your context parameters.
HTH.
Larry
> writer (me).
> Thanks again,
> Zohar.
>>Larry
>>>>Larry
>>>>>No logs to look at?
>>>>>>already checked.
>>>>>>Larry
>>>>>>>>Zohar,
>>>>>>>>you show below
>>>>>>>>an error.
>>>>>>>>is the problem.
>>>>>>>>Cheers,
>>>>>>>>Larry
>>>>>>>>Zohar wrote:
>>>>>>>>>Hello,
>>>>>>>>><Context>
>>>>>>>>></Context>
>>>>>>>>>parameters.
>>>>>>>>>Thanks,
>>>>>>>>>Zohar.
Re: context.xml [message #144456 is a reply to message #144438] |
Wed, 19 October 2005 14:48 |
So when I deploy my WAR file and indicate where its configuration file is,
it is equivalent to your P1 example? because it has a slightly different
syntax (similar to the one in context.xml).
news:dj5l94$f4c$1@news.eclipse.org...
> <web-app>
> <context-param>
> </context-param>
> <servlet>
> <init-param>
> </init-param>
> </servlet>
> </web-app>
> HTH.
> Larry
>> question).
>> writer (me).
>> as the one passed to init - so what's the difference?
>> Thanks again,
>> Zohar.
>>>Larry
>>>>><Context> element in the server.xml under
>>>>>that your servlet just doesn't see them? If the server.xml includes
>>>>>the parameter elements, what does your init method look like?
>>>>>Larry
>>>>>>No logs to look at?
>>>>>>>you've already checked.
>>>>>>>Larry
>>>>>>>>>Zohar,
>>>>>>>>>you show below
>>>>>>>>>at the beginning of the file. The Crimson XML parser obtained from
>>>>>>>>>the 1.4.x JRE or JDK doesn't handle this BOM and erroneously
>>>>>>>>>funny characters should appear at the beginning of the file, which
>>>>>>>>>can be deleted. Then set the encoding back to what it was.
>>>>>>>>>Cheers,
>>>>>>>>>Larry
>>>>>>>>>Zohar wrote:
>>>>>>>>>>Hello,
>>>>>>>>>>seem to have problems with my servlet's context.xml .
>>>>>>>>>><Context>
>>>>>>>>>></Context>
>>>>>>>>>>no parameters.
>>>>>>>>>>Thanks,
>>>>>>>>>>Zohar.
Re: context.xml [message #144465 is a reply to message #144456] |
Wed, 19 October 2005 15:03 |
I'm not exactly sure what is meant by "because it has a slightly
different syntax". What Tomcat would create internally for:
in your context.xml is identical to what it would create for:
<context-param>
</context-param>
in a web.xml. It's two ways of doing the same thing. Perhaps that's
what you mean by your last statement.
Larry
>><web-app>
>> <context-param>
>> </context-param>
>> <servlet>
>> <init-param>
>> </init-param>
>> </servlet>
>></web-app>
>>HTH.
>>Larry
>>>question).
>>>writer (me).
>>>Thanks again,
>>>Zohar.
>>>>Larry
>>>>>>Larry
>>>>>>>No logs to look at?
>>>>>>>>Larry
>>>>>>>>>>Zohar,
>>>>>>>>>>you show below
>>>>>>>>>>Cheers,
>>>>>>>>>>Larry
>>>>>>>>>>Zohar wrote:
>>>>>>>>>>>Hello,
>>>>>>>>>>><Context>
>>>>>>>>>>></Context>
>>>>>>>>>>>no parameters.
>>>>>>>>>>>Thanks,
>>>>>>>>>>>Zohar.
Re: context.xml [message #144474 is a reply to message #144465] |
Wed, 19 October 2005 15:07 |
Probably did. Any good place to read about all this?
news:dj5n8c$ia9$1@news.eclipse.org...
> I'm not exactly sure what is meant by "because it has a slightly different
> <context-param>
> </context-param>
> in a web.xml. It's two ways of doing the same thing. Perhaps that's what
> Larry
>> is, it is equivalent to your P1 example? because it has a slightly
>> different syntax (similar to the one in context.xml).
>>><web-app>
>>> <context-param>
>>> </context-param>
>>> <servlet>
>>> <init-param>
>>> </init-param>
>>> </servlet>
>>></web-app>
>>>HTH.
>>>Larry
>>>>question).
>>>>the writer (me).
>>>>object as the one passed to init - so what's the difference?
>>>>Thanks again,
>>>>Zohar.
>>>>>Larry
>>>>>>the enumeration is empty.
>>>>>>>method, the configuration I get contains no parameters" means that
>>>>>>>the <Context> element in the server.xml under
>>>>>>>Larry
>>>>>>>>No logs to look at?
>>>>>>>>>BOM, I'm only aware of XML syntax errors causing this, which I'm
>>>>>>>>>sure you've already checked.
>>>>>>>>>Larry
>>>>>>>>>>>Zohar,
>>>>>>>>>>>XML you show below
>>>>>>>>>>>The one mysterious way I am aware of to cause this problem is to
>>>>>>>>>>>be running Eclipse with a 1.4.x JRE or JDK and have a
>>>>>>>>>>>Byte-Order-Mark at the beginning of the file. The Crimson XML
>>>>>>>>>>>parser obtained from the 1.4.x JRE or JDK doesn't handle this BOM
>>>>>>>>>>>which can be deleted. Then set the encoding back to what it was.
>>>>>>>>>>>Cheers,
>>>>>>>>>>>Larry
>>>>>>>>>>>Zohar wrote:
>>>>>>>>>>>>Hello,
>>>>>>>>>>>><Context>
>>>>>>>>>>>></Context>
>>>>>>>>>>>>contains no parameters.
>>>>>>>>>>>>Thanks,
>>>>>>>>>>>>Zohar.
Re: context.xml [message #144501 is a reply to message #144465] |
Wed, 19 October 2005 15:51 |
whenever I run "ServletContext context = getServletContext();" in the init
method or the doPost method) I get NPE - any idea why?
> <context-param>
> </context-param>
> Larry
>>><web-app>
>>> <context-param>
>>> </context-param>
>>> <servlet>
>>> <init-param>
>>> </init-param>
>>> </servlet>
>>></web-app>
>>>HTH.
>>>Larry
>>>>question).
>>>>the writer (me).
>>>>Thanks again,
>>>>Zohar.
>>>>>Larry
>>>>>>>Larry
>>>>>>>>No logs to look at?
>>>>>>>>>Larry
>>>>>>>>>>>Zohar,
>>>>>>>>>>>XML you show below
>>>>>>>>>>>Cheers,
>>>>>>>>>>>Larry
>>>>>>>>>>>Zohar wrote:
>>>>>>>>>>>>Hello,
>>>>>>>>>>>><Context>
>>>>>>>>>>>></Context>
>>>>>>>>>>>>Thanks,
>>>>>>>>>>>>Zohar.
Re: context.xml [message #144520 is a reply to message #144465] |
Wed, 19 October 2005 16:40 |
Thank you very much for all the help. Hope to return the favor one day.
> <context-param>
> </context-param>
> Larry
>>><web-app>
>>> <context-param>
>>> </context-param>
>>> <servlet>
>>> <init-param>
>>> </init-param>
>>> </servlet>
>>></web-app>
>>>HTH.
>>>Larry
>>>>question).
>>>>the writer (me).
>>>>Thanks again,
>>>>Zohar.
>>>>>Larry
>>>>>>>Larry
>>>>>>>>No logs to look at?
>>>>>>>>>Larry
>>>>>>>>>>>Zohar,
>>>>>>>>>>>XML you show below
>>>>>>>>>>>Cheers,
>>>>>>>>>>>Larry
>>>>>>>>>>>Zohar wrote:
>>>>>>>>>>>>Hello,
>>>>>>>>>>>><Context>
>>>>>>>>>>>></Context>
>>>>>>>>>>>>Thanks,
>>>>>>>>>>>>Zohar.
Re: context.xml [message #144530 is a reply to message #144501] |
Wed, 19 October 2005 17:05 |
I will guess that you are using "init(ServletConfig config)" instead of
"init()" and you *aren't* calling "super.init(config)", which is
required by the servlet spec to initialize the ServletConfig field for
the servlet. Since getServletContext() uses the ServletConfig field to
get the ServletContext, you get an NPE. The simplest way to fix this is
to switch to the "init()" version of the method, which is the
recommended method to use. If you are curious, see the GenericServlet
source as to how this happens:
http://svn.apache.org/repos/asf/tomcat/servletapi/servlet2.4 -jsp2.0-tc5.x/jsr154/src/share/javax/servlet/GenericServlet. java
As for where to read about this stuff, I would imagine most any Servlet
book would cover this. If you already know a little about the
information you are looking for, you may be able to find the detail you
want in the Servlet specs themselves. The Servlet spec can be a tough
read otherwise.
Larry
>> <context-param>
>> </context-param>
>>Larry
>>>><web-app>
>>>> <context-param>
>>>> </context-param>
>>>> <servlet>
>>>> <init-param>
>>>> </init-param>
>>>> </servlet>
>>>></web-app>
>>>>HTH.
>>>>Larry
>>>>>question).
>>>>>the writer (me).
>>>>>Thanks again,
>>>>>Zohar.
>>>>>>Larry
>>>>>>>>Larry
>>>>>>>>>No logs to look at?
>>>>>>>>>>Larry
>>>>>>>>>>>>Zohar,
>>>>>>>>>>>>XML you show below
>>>>>>>>>>>>Cheers,
>>>>>>>>>>>>Larry
>>>>>>>>>>>>Zohar wrote:
>>>>>>>>>>>>>Hello,
>>>>>>>>>>>>><Context>
>>>>>>>>>>>>></Context>
>>>>>>>>>>>>>Thanks,
>>>>>>>>>>>>>Zohar.
Re: context.xml [message #144539 is a reply to message #144530] |
Wed, 19 October 2005 17:21 |
Yes, that was it - not invoking super... :$
Thanks.
news:dj5ucf$sl0$1@news.eclipse.org...
>"init()" and you *aren't* calling "super.init(config)", which is required
>by the servlet spec to initialize the ServletConfig field for the servlet.
>Since getServletContext() uses the ServletConfig field to get the
>ServletContext, you get an NPE. The simplest way to fix this is to switch
>to the "init()" version of the method, which is the recommended method to
>use. If you are curious, see the GenericServlet source as to how this
>happens:
> book would cover this. If you already know a little about the information
> you are looking for, you may be able to find the detail you want in the
> Servlet specs themselves. The Servlet spec can be a tough read otherwise.
> Larry
>> init method or the doPost method) I get NPE - any idea why?
>>> <context-param>
>>> </context-param>
>>>Larry
>>>>><web-app>
>>>>> <context-param>
>>>>> </context-param>
>>>>> <servlet>
>>>>> <init-param>
>>>>> </init-param>
>>>>> </servlet>
>>>>></web-app>
>>>>>HTH.
>>>>>Larry
>>>>>>question).
>>>>>>with WTP? I want these parameters to be set by the servlet's deployer,
>>>>>>not the writer (me).
>>>>>>Thanks again,
>>>>>>Zohar.
>>>>>>>equivalent context parameters. To read them, I believe you want:
>>>>>>>Larry
>>>>>>>>>includes the parameter elements, what does your init method look
>>>>>>>>>like?
>>>>>>>>>Larry
>>>>>>>>>>No logs to look at?
>>>>>>>>>>>Larry
>>>>>>>>>>>>possible causes for this? can I check some logs for this
>>>>>>>>>>>>somewhere?
>>>>>>>>>>>>>Zohar,
>>>>>>>>>>>>>XML you show below
>>>>>>>>>>>>>to be running Eclipse with a 1.4.x JRE or JDK and have a
>>>>>>>>>>>>>Cheers,
>>>>>>>>>>>>>Larry
>>>>>>>>>>>>>Zohar wrote:
>>>>>>>>>>>>>>Hello,
>>>>>>>>>>>>>>still seem to have problems with my servlet's context.xml .
>>>>>>>>>>>>>>WebContent/META-INF directory. In that xml file I've put
>>>>>>>>>>>>>>something like:
>>>>>>>>>>>>>><Context>
>>>>>>>>>>>>>></Context>
>>>>>>>>>>>>>>Thanks,
>>>>>>>>>>>>>>Zohar.
Current Time: Sat Apr 27 05:08:45 GMT 2024
Powered by FUDForum. Page generated in 0.04984 seconds
