Fast retrieval of an EClassifier by qualified name and root EPackage [message #924202] |
Wed, 26 September 2012 15:55 |
Tassilo Horn Messages: 93 Registered: July 2009 |
Member |
Hi all,
say you have some root EPackage of an ecore model and the fully
qualified name of an EClassifier, e.g., the EPackage foo and the qname
"foo.bar.Baz". Is there a faster way to retrieve the EClassifier Baz
except for checking foo.getESubpackages() for an EPackage with name
"baz", and then getEClassifier("Baz") (possibliy recursively if there's
a deeper package nesting)? Basically, why is there no constant-time
lookup method
EPackage getESubpackage(String)
when there's
EClassifier getEClassifier(String)
in EPackage.
With some metamodels with lots of sub-EPackages (JaMoPP for example),
that's pretty slow if you do such lookups often.
Maybe another way was to use the nsURIs and the package registry
instead. If the package foo has the nsURI "http://foo", is it
guaranteed that the package foo.bar has the nsURI "http://foo/bar"?
That's the case for all Ecore models I've ever seen, but you never
know...
Bye,
Tassilo
Dipl.-Inform. Tassilo Horn | Room: B015
University of Koblenz-Landau, Campus Koblenz | Phone: +49 (261) 287-2745
Institute for Software Technology | Mail: horn@xxxxxxxx
Universitätsstr. 1, 56070 Koblenz, Germany |
Re: Fast retrieval of an EClassifier by qualified name and root EPackage [message #924747 is a reply to message #924202] |
Thu, 27 September 2012 05:09 |
Ed Merks Messages: 33142 Registered: July 2009 |
Tassilo,
Comments below.
On 26/09/2012 5:55 PM, Tassilo Horn wrote:
> Hi all,
> lookup method
No. Generally nsURIs are used to locate packages.
> when there's
> in EPackage.
You can always build a map once. It's not so common to have a qualified
name you need to look up. Whereas looking up features and classifiers
by name is common because deserializers often need to do that.
> instead.
Yes, the registry is how the package is normally looked up quickly.
No.
> know...
If you're looking for base lookup in generated models, the nsURI and the
classifier name are the best way.
> Bye,
> Tassilo
Ed Merks
Re: Fast retrieval of an EClassifier by qualified name and root EPackage [message #924865 is a reply to message #924747] |
Thu, 27 September 2012 07:33 |
Member |
Ed Merks <ed.merks@xxxxxxxx> writes:
Hi Ed,
>> when there's
>> in EPackage.
> qualified name you need to look up. Whereas looking up features and
> classifiers by name is common because deserializers often need to do
> that.
I do model querying on EMF models, and at least there it seems to me
that qualified names are rather common. I mean, it's much easier for a
user to write something along the lines of
forall (class : model.allInstancesOf("java.classifiers.Class")) ...
than
"http://www.emftext.org/java/classifiers/Class")) ...
I know all the nsURIs of packages, so I guess I'll use a map like
{ baseNsURI -> { qname -> package }}
Tassilo
FUDForum. Page generated in 0.02594 seconds
