Re: Need help with C++ for Eclipse [message #895154 is a reply to message #894662] |
Wed, 11 July 2012 20:12 |
Jo Po Messages: 4 Registered: July 2012 |
Junior Member |
Ok, I go to file >> new >> c++ project. under project type, I have GNU Autotools and it is expanded and contains Empty Porject, Hello WOrld C++ Autotools Project, Autotools Shared Library Project. Under all that, I have Executable, Shared Library, Static Library, and Makefile Project. I click on Executable but it blanks out the Finish button and I cannot proceed. Under Toolschains, this pops up, Project catergory is selected. Expand category and select a concrete project type.
I click on Executable and it won't expand or do anything. And I can't proceed...
Re: Need help with C++ for Eclipse [message #895233 is a reply to message #895154] |
Thu, 12 July 2012 08:29 |
Axel Mueller Messages: 1973 Registered: July 2009 |
Jo Po wrote on Wed, 11 July 2012 22:12Ok, I go to file >> new >> c++ project. under project type, I have GNU Autotools and it is expanded and contains Empty Porject, Hello WOrld C++ Autotools Project, Autotools Shared Library Project. Under all that, I have Executable, Shared Library, Static Library, and Makefile Project. I click on Executable but it blanks out the Finish button and I cannot proceed. Under Toolschains, this pops up, Project catergory is selected. Expand category and select a concrete project type.
That's a bug https://bugs.eclipse.org/bugs/show_bug.cgi?id=383032
The bug has been fixed after the Juno release. There is a workaround mentioned in the bug report:
Quote:"The "expand/collapse" control is there but it is behind the left edge. If you move the slide on the bottom to the left it will reveal the "expand/collapse" control."
Before you ask
- search this forum
- see the FAQ http://wiki.eclipse.org/CDT/User/FAQ
- google
FUDForum. Page generated in 0.03502 seconds
