.classpath problem? [message #118319] |
Thu, 17 November 2005 14:04 |
Originally posted by: luca.rasconi.gmail.com
what's the meaning of Path '/' must denote location inside project
simple-servlet?
i imported a simple project in eclipse and i had this error:
this is mi .classpath file:
<classpath>
<classpathentry kind="src" path="src/main/java"/>
<classpathentry kind="src" path="src/main/resources" output=".."/>
<classpathentry kind="output" path="target/classes"/>
<!--classpathentry kind="var" rootpath="JRE_SRCROOT" path="JRE_LIB"
sourcepath="JRE_SRC"/-->
<classpathentry kind="var"
path=" M2_REPO/commons-collections/commons-collections/3.1/commons- collections-3.1.jar "/>
path="M2_REPO/junit/junit/3.8.1/junit-3.8.1.jar"/>
path=" M2_REPO/alice-commons/alice-commons/1.2/alice-commons-1.2.ja r "/>
<classpathentry kind="var" path="M2_REPO/jsdk/jsdk/24/jsdk-24.jar"/>
</classpath>
where M2_REPO is visible by eclipse.
every suggestion is very appreciated.
Bye,
Luca
Re: .classpath problem? [message #118483 is a reply to message #118319] |
Fri, 18 November 2005 22:13 |
Originally posted by: eclipse3.rizzoweb.com
> simple-servlet?
> <classpath>
> </classpath>
What is the error?
Note: editing .classpath manually is not necessary - you should open the
Project > Properties dialog and select the Java Build Path section.
HTH,
Eric
FUDForum. Page generated in 0.07849 seconds
