Home » Modeling » TMF (Xtext) » Problem with XtextLinkingDiagnostic
Problem with XtextLinkingDiagnostic [message #882975] Thu, 07 June 2012 11:09 Go to next message
Hey,
I would like to perform the generation process without need of starting an Eclipse instance. It just takes to much time and I'm currently working only on the generation process. The process works fine if I just use one Resource for generation.
If I have two Resources that contain references to each other, the validation results in the following error :
XtextLinkingDiagnostic: null:51 Couldn't resolve reference to SubProduct 'productNameXYZ'.
Here is the extracted part of my GenerationClass:
@Inject
private Provider<ResourceSet> resourceSetProvider;
@Inject
private IResourceValidator validator;
@Inject
private IGenerator generator;
@Inject
private JavaIoFileSystemAccess fileAccess;
    if (args.length == 0) {
	System.err.println("Aborting: no path to EMF resource provided!");
	return;
    Injector injector = new org.product.ProductStandaloneSetupGenerated()
				.createInjectorAndDoEMFRegistration();
    ProductGeneratorRunner main = injector
				.getInstance(ProductGeneratorRunner.class);
    main.setOutputPath(ProductBuilder.PFODUCT_GEN_DIRECTORY);
    main.runGenerator(args);
public List<Issue> runGenerator(String[] paths) {
	// load the resource
	ResourceSet set = resourceSetProvider.get();
	List<Resource> resources = new ArrayList<Resource>();
	for (String path : paths) {
		Resource resource = set.getResource(URI.createURI(path), true);
		resources.add(resource);
	for (Resource resource : resources) {
		List<Issue> issues = validator.validate(resource, CheckMode.ALL,
				CancelIndicator.NullImpl);
		if (!issues.isEmpty()) {
			for (Issue issue : issues) {
				System.err.println(issue);
			return issues;
		fileAccess.setOutputPath(outputPath);
		generator.doGenerate(resource, fileAccess);
	System.out.println("Code generation finished.");
	return null;
Somehow is Xtext aware of the referenced file if I execute the generation process with an Eclipse instance. How can I resolve this issue? Thank you.
Kon
Re: Problem with XtextLinkingDiagnostic [message #883000 is a reply to message #882975] Thu, 07 June 2012 12:02 Go to previous message
i cannot reproduce this problem. please note: in standalone mode you have to add all involved resource to the resourceset.
so are you sure you added the file containing productNameXYZ to the resourceset?
~Christian
Previous Topic:Ecore Modell from extisting Grammar
Next Topic:How to support implicit imports?
Current Time: Tue Jul 08 09:53:16 EDT 2025
Powered by FUDForum. Page generated in 0.06606 seconds
