Re: Insert file into BIRT report [message #871052 is a reply to message #870847] |
Thu, 10 May 2012 16:35 |
BIRT supports Java object types but what would you want the export to do?
Jason
On 5/9/2012 5:34 PM, Leticia Simental wrote:
> Hi everybody
> I'm wondering if there's a way to insert a file into the report and then export it??
> Like Excel's functionality 'Insert> Object> Create a file'
> Attached an image to clarify
> Thanks a lot!! :d
Re: Insert file into BIRT report [message #871084 is a reply to message #871065] |
Thu, 10 May 2012 18:07 |
Understood. Currently the xls emitter does not support this.
Jason
On 5/10/2012 1:28 PM, Leticia Simental wrote:
> Well, i expecting an Excel file with some other files inserted in the file (into cells)
> Attached an example
> Thanks Jason
Re: Insert file into BIRT report [message #871092 is a reply to message #871085] |
Thu, 10 May 2012 19:38 |
This feature could be implemented with the emitter framework extension
and possibly a new report item extension.
Jason
On 5/10/2012 2:24 PM, Leticia Simental wrote:
> Oooh what a shame! :(
> Thanks you very much for your quick answer Jason!
> Regards!!
FUDForum. Page generated in 0.03160 seconds
