Home » Eclipse Projects » Equinox » java.lang.NoClassDefFoundError: org/eclipse/core/runtime/FileLocator
java.lang.NoClassDefFoundError: org/eclipse/core/runtime/FileLocator [message #112450] |
Tue, 24 June 2008 18:45 |
Originally posted by: mburbidg.adobe.com
I'm getting the following exception:
com.adobe.clover.deployer.DeployBundleJob.initialize(DeployB undleJob.java:37)
com.adobe.clover.deployer.DeployBundleJob.execute(DeployBund leJob.java:23)
at org.quartz.core.JobRunShell.run(JobRunShell.java:202)
org.quartz.simpl.SimpleThreadPool$WorkerThread.run(SimpleThr eadPool.java:529)
So I added org.eclipse.core.runtime to my manifest imports, which look
like:
Import-Package: javax.xml.parsers,
org.apache.commons.lang,org.apache.commons.lang.exception,or g.apache.commons.lang.text,
org.apache.commons.logging,org.apache.commons.logging.impl,
org.apache.commons.beanutils,
org.apache.commons.configuration,
org.quartz,
org.springframework.beans.factory,
org.springframework.scheduling.quartz,
org.w3c.dom, org.apache.xml.serialize,
org.osgi.framework,
Now I don't get a runtime exception, but the equinox log contains the
following entry:
!ENTRY com.adobe.clover.deployer 4 0 2008-06-24 11:37:46.775
!MESSAGE
!STACK 0
org.osgi.framework.BundleException: The bundle could not be resolved.
Reason: Missing Constraint: Import-Package: org.eclipse.core.runtime;
version="0.0.0"
org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:305)
org.eclipse.osgi.framework.internal.core.AbstractBundle.resu me(AbstractBundle.java:350)
org.eclipse.osgi.framework.internal.core.Framework.resumeBun dle(Framework.java:1118)
org.eclipse.osgi.framework.internal.core.StartLevelManager.r esumeBundles(StartLevelManager.java:634)
org.eclipse.osgi.framework.internal.core.StartLevelManager.i ncFWSL(StartLevelManager.java:508)
org.eclipse.osgi.framework.internal.core.StartLevelManager.d oSetStartLevel(StartLevelManager.java:282)
org.eclipse.osgi.framework.internal.core.StartLevelManager.d ispatchEvent(StartLevelManager.java:468)
org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEve nt(EventManager.java:195)
org.eclipse.osgi.framework.eventmgr.EventManager$EventThread .run(EventManager.java:297)
!ENTRY org.eclipse.osgi 4 0 2008-06-24 11:37:47.441
!MESSAGE Bundle
initial@reference:file:foundation/com.adobe.clover.deployer.jar/ was not
resolved.
The package org.eclipse.core.runtime is in the equnix bundle named
org.eclipse.equinox.common_3.3.0.v20070426.jar, which I start up as the
first bundle. This is what is in my config.ini:
osgi.bundles=\
foundation/org.eclipse.equinox.common_3.3.0.v20070426.jar@:s tart,\
foundation/com.springsource.org.apache.commons.logging-1.1.1 .jar,\
foundation/com.adobe.clover.deployer.jar@:start
If I do a status from the equinox command prompt I can see that the bundle
org.eclipse.equinox.common_3.3.0.v20070426.jar is started. I don't
understand why my bundle can't resolve it's reference to this bundle.
Any suggestions?
Michael-
Re: java.lang.NoClassDefFoundError: org/eclipse/core/runtime/FileLocator [message #112463 is a reply to message #112450] |
Tue, 24 June 2008 21:30 |
I believe this is because the package org.eclipse.core.runtime is
partially implemented in two different bundles. I believe this confuses
equinox. I have had this problem before with partially implemented
packages in different bundles. Both
org.eclipse.osgi_3.3.2.R33x_v20080105.jar and
org.eclipse.equinox.common_3.3.0.v20070426.jar have partial
implementations of org.eclipse.core.runtime.
Please if anyone can enlighten me as to what is going on here I would
really appreciate it. I must have some fundamental misunderstanding of
OSGi. I'm about ready to give up on it because of constant wrestling and
frustration with dependencies.
Michael-
Re: java.lang.NoClassDefFoundError: org/eclipse/core/runtime/FileLocator [message #112503 is a reply to message #112450] |
Wed, 25 June 2008 14:39 |
Oleg Besedin Messages: 41 Registered: July 2009 |
Member |
------=_NextPart_000_0017_01C8D6AF.B8914C50
Content-Type: text/plain;
charset="iso-8859-15"
Hi Michael,
If you'd like to depend on the org.eclipse.equinox.common bundle only, =
put the following line in the Import statements:
Import-Package: org.eclipse.core.runtime;common=3Dsplit,
or use:
Require-Bundle: org.eclipse.equinox.common
I do agree that split packages are rather confusing. Hope this helps.
Oleg
"Michael Burbidge" <mburbidg@adobe.com> wrote in message =
news:9d28f0e393e4b26cd81f0bf42ca97fee$1@www.eclipse.org...
>=20
> at=20
com.adobe.clover.deployer.DeployBundleJob.initialize(DeployB undleJob.java=
:37)
> at=20
com.adobe.clover.deployer.DeployBundleJob.execute(DeployBund leJob.java:23=
> at=20
org.quartz.simpl.SimpleThreadPool$WorkerThread.run(SimpleThr eadPool.java:=
529)
>=20
> So I added org.eclipse.core.runtime to my manifest imports, which look =
> like:
>=20
org.apache.commons.lang,org.apache.commons.lang.exception,or g.apache.comm=
ons.lang.text,
> org.quartz,
> org.osgi.framework,
>=20
> Now I don't get a runtime exception, but the equinox log contains the=20
> following entry:
>=20
> !MESSAGE=20
> !STACK 0
> org.osgi.framework.BundleException: The bundle could not be resolved.=20
> Reason: Missing Constraint: Import-Package: org.eclipse.core.runtime;=20
> version=3D"0.0.0"
> at=20
org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHos=
t.java:305)
> at=20
org.eclipse.osgi.framework.internal.core.AbstractBundle.resu me(AbstractBu=
ndle.java:350)
> at=20
org.eclipse.osgi.framework.internal.core.Framework.resumeBun dle(Framework=
..java:1118)
> at=20
org.eclipse.osgi.framework.internal.core.StartLevelManager.r esumeBundles(=
> at=20
org.eclipse.osgi.framework.internal.core.StartLevelManager.i ncFWSL(StartL=
> at=20
org.eclipse.osgi.framework.internal.core.StartLevelManager.d oSetStartLeve=
> at=20
org.eclipse.osgi.framework.internal.core.StartLevelManager.d ispatchEvent(=
> at=20
org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEve nt(EventManag=
er.java:195)
> at=20
org.eclipse.osgi.framework.eventmgr.EventManager$EventThread .run(EventMan=
ager.java:297)
>=20
> !MESSAGE Bundle=20
> initial@reference:file:foundation/com.adobe.clover.deployer.jar/ was =
not=20
> resolved.
>=20
> The package org.eclipse.core.runtime is in the equnix bundle named=20
> org.eclipse.equinox.common_3.3.0.v20070426.jar, which I start up as =
the=20
>=20
> osgi.bundles=3D\
>=20
> If I do a status from the equinox command prompt I can see that the =
bundle=20
> org.eclipse.equinox.common_3.3.0.v20070426.jar is started. I don't=20
>=20
> Any suggestions?
>=20
> Michael-
>=20
>=20
Content-Type: text/html;
<HTML><HEAD>
charset=3Diso-8859-15">
<META content=3D"MSHTML 6.00.2900.3354" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<BODY>
<DIV><FONT face=3DArial size=3D2>Hi Michael,</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>If you'd like to depend on the=20
org.eclipse.equinox.common bundle only, put the following line in the =
Import=20
statements:</FONT></DIV>
<DIV><FONT face=3DArial size=3D2></FONT> </DIV>
<DIV><FONT face=3DArial size=3D2> Import-Package:=20
org.eclipse.core.runtime<STRONG>;common=3Dsplit</STRONG>, </FONT></DIV>
<DIV><FONT face=3DArial size=3D2>or use:</FONT></DIV>
<DIV><FONT face=3DArial size=3D2> Require-Bundle:=20
org.eclipse.equinox.common</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>I do agree that split packages are =
rather=20
confusing. </FONT><FONT face=3DArial size=3D2>Hope this =
helps.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Thanks,</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Oleg</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>"Michael Burbidge" <</FONT><A=20
href=3D"mailto:mburbidg@adobe.com"><FONT face=3DArial=20
size=3D2>mburbidg@adobe.com</FONT></A><FONT face=3DArial size=3D2>> =
wrote in=20
message </FONT><A=20
href=3D"news:9d28f0e393e4b26cd81f0bf42ca97fee$1@www.eclipse.org"><FONT =
face=3DArial=20
size=3D2>news:9d28f0e393e4b26cd81f0bf42ca97fee$1@www.eclipse.org</FONT></=
A><FONT=20
face=3DArial size=3D2>...</FONT></DIV><FONT face=3DArial size=3D2>> =
I'm getting the=20
following exception:<BR>> <BR>> java.lang.NoClassDefFoundError:=20
org/eclipse/core/runtime/FileLocator<BR>> at <BR>>=20
:37)<BR>>=20
at <BR>>=20
)<BR>>=20
at org.quartz.core.JobRunShell.run(JobRunShell.java:202)<BR>> at =
<BR>>=20
529)<BR>>=20
<BR>> So I added org.eclipse.core.runtime to my manifest imports, =
which look=20
<BR>> like:<BR>> <BR>> Import-Package: =20
javax.xml.parsers,<BR> > org.apache.commons.lang,org.apache.common=
s.lang.exception,org.apache.commons.lang.text,<BR>> org.apache.co=
mmons.logging,org.apache.commons.logging.impl,<BR>> org.apache.co=
mmons.beanutils,<BR>> org.apache.commons.configuration, <BR>>&n=
bsp;org.quartz,<BR>> org.springframework.beans.factory, <BR>>&n=
bsp;org.springframework.scheduling.quartz,<BR>> org.w3c.dom,=20
org.apache.xml.serialize,<BR>> org.osgi.framework, <BR>> o=
rg.eclipse.core.runtime<BR>>=20
<BR>> Now I don't get a runtime exception, but the equinox log =
contains the=20
<BR>> following entry:<BR>> <BR>> !ENTRY =
com.adobe.clover.deployer 4 0=20
2008-06-24 11:37:46.775<BR>> !MESSAGE <BR>> !STACK 0<BR>>=20
org.osgi.framework.BundleException: The bundle could not be resolved. =
<BR>>=20
Reason: Missing Constraint: Import-Package: org.eclipse.core.runtime; =
<BR>>=20
version=3D"0.0.0"<BR>> at <BR>>=20
t.java:305)<BR>>=20
at <BR>>=20
ndle.java:350)<BR>>=20
at <BR>>=20
..java:1118)<BR>>=20
at <BR>>=20
StartLevelManager.java:634)<BR>>=20
at <BR>>=20
evelManager.java:508)<BR>>=20
at <BR>>=20
l(StartLevelManager.java:282)<BR>>=20
at <BR>>=20
StartLevelManager.java:468)<BR>>=20
at <BR>>=20
er.java:195)<BR>>=20
at <BR>>=20
ager.java:297)<BR>>=20
<BR>> !ENTRY org.eclipse.osgi 4 0 2008-06-24 11:37:47.441<BR>> =
!MESSAGE=20
Bundle <BR>> </FONT><A=20
href=3D"mailto:initial@reference:file:foundation/com.adobe.clover.deploye=
r.jar/"><FONT=20
face=3DArial=20
size=3D2>initial@reference:file:foundation/com.adobe.clover.deployer.jar/=
</FONT></A><FONT=20
face=3DArial size=3D2> was not <BR>> resolved.<BR>> <BR>> The =
package=20
org.eclipse.core.runtime is in the equnix bundle named <BR>>=20
org.eclipse.equinox.common_3.3.0.v20070426.jar, which I start up as the =
<BR>>=20
first bundle. This is what is in my config.ini:<BR>> <BR>>=20
osgi.bundles=3D\<BR>> </FONT><A=20
href=3D" mailto:foundation/org.eclipse.equinox.common_3.3.0.v20070426 .jar@=
:start,\"><FONT=20
face=3DArial=20
size=3D2> foundation/org.eclipse.equinox.common_3.3.0.v20070426.jar@:s tart=
,\</FONT></A><BR><FONT=20
face=3DArial size=3D2>>=20
foundation/com.springsource.org.apache.commons.logging-1.1.1 .jar,\ <BR>>=
;=20
...<BR>> </FONT><A=20
href=3D"mailto:foundation/com.adobe.clover.deployer.jar@:start "><FONT =
face=3DArial=20
size=3D2>foundation/com.adobe.clover.deployer.jar@:start</FONT ></A><BR><F=
ONT=20
face=3DArial size=3D2>> <BR>> If I do a status from the equinox =
command prompt=20
I can see that the bundle <BR>>=20
org.eclipse.equinox.common_3.3.0.v20070426.jar is started. I don't =
<BR>>=20
understand why my bundle can't resolve it's reference to this =
bundle.<BR>>=20
<BR>> Any suggestions?<BR>> <BR>> Michael-<BR>> <BR>>=20
<BR>></FONT></BODY></HTML>
------=_NextPart_000_0017_01C8D6AF.B8914C50--
Current Time: Fri Apr 26 20:01:54 GMT 2024
Powered by FUDForum. Page generated in 0.02936 seconds
