Drag & drop canvas figure item On RCP program [message #822792] |
Sat, 17 March 2012 08:59 |
ScoldField Martin Messages: 3 Registered: March 2012 Location: China |
Junior Member |
Dear Alex:
I am trying to use jubula to test a RCP/SWT program.
I can't find the sample about the operation of canvas figure,
such as drag,drop,right click, etc.
when i add a referent of ub_fcv_dragAndDropFigure_byTextPath,
i put the textpath parameter which i copy from the GEF inspector view,
set the source and dest value, in the object map view, i map one of the
canvas figure to the action.
After all of than done, i run the test suit, and i always failed.
Could you give me some suggestion or sample?
ths.
Best Regards
Martin.Scolfield
Re: Drag & drop canvas figure item On RCP program [message #829455 is a reply to message #824873] |
Mon, 26 March 2012 10:08 |
Junior Member |
hi, Alex:
Thank you for your response.
The probleam remains unresolved.
About the error log message, i'm sorry that i don't
know where it locate, i can only get the info from excution
perspective view. It showed that error type is 'Action error',
withow further descripthion.
For now, there are another three probleam, i will describe
them as possible as clearly.
1. The action which clicks canvas figure, named ub_fcv_clickFi
ure_byTextPath, does not work, but the action (select canvas figure)
ub_fcv_selectTool_byTextPath work. The error action type is action error.
2. I could not map the component in the modal pop-up dialog with jubula,
in the object map view, ctr+shift+q doesn't work, and there is no yellow bound on
on the component. If the dialog is not modal, it work.
3. when i map a swt table in object map view, the jubula recognize the table
to be a tree. In the sample swt application it recognizes correctly, but in my
application it doesn't.
Thank you for your help.
Best Regards
Martin ScoldField
FUDForum. Page generated in 0.03405 seconds
