Home » Eclipse Projects » EGit / JGit » aborting a merge
aborting a merge [message #800878] Fri, 17 February 2012 11:21 Go to next message
I know egit supports aborting a rebase but as far as I know it doesn't support aborting a merge. Is that correct? If so, is there some difficulty that's getting in the way of adding this feature? It's a pretty important part of normal git merge usage, just as it is in rebase.
Re: aborting a merge [message #801395 is a reply to message #800878] Sat, 18 February 2012 04:52 Go to previous messageGo to next message
R Shapiro skrev 2012-02-17 17.21:
A hard reset should do. Now that is not always the same as git merge --abort in that reset forgets all changes,
while git merge --abort tries to retain changes that were not committed prior to the merge. Not that the
git manual discourages merging when uncommitted changes are present.
-- robin
Re: aborting a merge [message #802970 is a reply to message #801395] Mon, 20 February 2012 13:58 Go to previous message
Right, I have that alternative documented in my own egit-notes, and I see now that it's also in the Egit help. For sure I agree it's a bad idea to merge into a branch with uncomitted changes.
Still, an explicit 'abort merge' egit operation seems like it's worth adding, even if the implementation is the same as a hard reset to HEAD (maybe with an additional check for uncommitted changes).
Previous Topic:JGit
Next Topic:is HTTP authentication broken again?
Current Time: Wed Jul 16 04:56:39 EDT 2025
Powered by FUDForum. Page generated in 3.86768 seconds
