Home » Eclipse Projects » Remote Application Platform (RAP) » Popup menu doesn't work on ToolBar in CTabFolder top-right
Re: Popup menu doesn't work on ToolBar in CTabFolder top-right [message #92605 is a reply to message #92547] |
Tue, 10 June 2008 21:06 |
Originally posted by: rherrmann.innoopract.com
Hi Enrico,
thanks for the hint. We will look into this and post the results here.
Rüdiger
Enrico Zanaga wrote:
> Hi all,
> I've created a ToolBar with only one ToolItem of type SWT.DROP_DOWN,
> then I've set the ToolBar as the top-right component of a CTabFolder
> using setTopRight(...).
> In the widgetSelected event of the ToolItem I show a modal popup menu.
> When I click on the drop down arrow of ToolItem, the browser (both IE7
> and Firefox2.0) dumps a javascript error.
> It's a bug or there's another method to show popup menu from ToolItem?
> I attach the code snippet and the output from IE7 and Firefox2.0
> Enrico
Re: Popup menu doesn't work on ToolBar in CTabFolder top-right [message #92873 is a reply to message #92547] |
Wed, 11 June 2008 15:31 |
Originally posted by: ifurnadjiev.innoopract.com
Hi Enrico,
first of all I can't find these too classes WFToolBar/WFToolItem, that's
why I reworked your snippet based on ToolBar/ToolItem (see the snippet
bellow). Hope that it's working for you.
final ToolBar tftb = new ToolBar(tf, SWT.HORIZONTAL | SWT.FLAT);
tf.setTopRight(tftb);
final ToolItem tfti1 = new ToolItem(tftb, SWT.DROP_DOWN);
tfti1.setText("Tool");
tfti1.addSelectionListener(new SelectionAdapter() {
public void widgetSelected(SelectionEvent e) {
if( e.detail == SWT.ARROW ) {
Menu m = new Menu( tftb.getShell(), SWT.POP_UP );
MenuItem mi1 = new MenuItem(m, SWT.NONE);
mi1.setText("First");
MenuItem mi2 = new MenuItem(m, SWT.NONE);
mi2.setText("Second");
Point point = new Point( e.x, e.y );
m.setLocation( point );
m.setVisible( true );
Best,
Ivan
> Hi all,
> Enrico
Re: Popup menu doesn't work on ToolBar in CTabFolder top-right [message #92887 is a reply to message #92873] |
Wed, 11 June 2008 15:54 |
Enrico Zanaga Messages: 50 Registered: July 2009 |
Member |
Hi Ivan,
sorry, it's my mistake.
However the reworked code doesn't work for me, but it's working for you?
If yes, can you tell me what version (RAP, Eclipse) are you using, please?
I try the code in 1.1M3 and 1.1RC3 without success...
Enrico
Ivan Furnadjiev ha scritto:
> Hi Enrico,
> @Override
> Best,
> Ivan
>> Hi all,
>> Thanks,
>> Enrico
Re: Popup menu doesn't work on ToolBar in CTabFolder top-right [message #92901 is a reply to message #92887] |
Wed, 11 June 2008 16:19 |
Hi Enrico,
I run it against 1.1RC3 in FF 2.0.0.14, IE7 and Safari 3.1.1 on Windows
XP SP3.
What kind of problems do you have - JavaScript error? Did you use the
exact snippet from my previous post?
Best,
Ivan
> Hi Ivan,
> please?
> Enrico
>> Hi Enrico,
>> that's why I reworked your snippet based on ToolBar/ToolItem (see the
>> snippet bellow). Hope that it's working for you.
>> @Override
>> Best,
>> Ivan
>>> Hi all,
>>> IE7 and Firefox2.0) dumps a javascript error.
>>> Thanks,
>>> Enrico
Re: Popup menu doesn't work on ToolBar in CTabFolder top-right [message #92916 is a reply to message #92901] |
Wed, 11 June 2008 16:57 |
Member |
Hi Ivan,
running your snippet in IE7, I get the following javascript error:
Could not evaluate javascript response:
'null' è nullo o non è un oggetto
org.eclipse.swt.EventUtil.suspendEventHandling();var req =
org.eclipse.swt.Request.getInstance();req.setRequestCounter( "3" );var
wm = org.eclipse.swt.WidgetManager.getInstance();wm.dispose( "w15"
);wm.dispose( "w14" );wm.dispose( "w13"
);qx.ui.core.Widget.flushGlobalQueues();org.eclipse.swt.Even tUtil.resumeEventHandling();
Maybe a qooxdoo problem?
In Jetty/Eclipse console nothing happen...
Enrico
> Hi Enrico,
> XP SP3.
> Best,
> Ivan
>> Hi Ivan,
>> please?
>> Thanks,
>> Enrico
>>> Hi Enrico,
>>> @Override
>>> Best,
>>> Ivan
>>>> Hi all,
>>>> Thanks,
>>>> Enrico
Re: Popup menu doesn't work on ToolBar in CTabFolder top-right [message #93004 is a reply to message #92916] |
Thu, 12 June 2008 07:07 |
Hi Enrico,
please attach your complete file to have a look at it.
Ivan
> Hi Ivan,
> Enrico
>> Hi Enrico,
>> Windows XP SP3.
>> Best,
>> Ivan
>>> Hi Ivan,
>>> you?
>>> please?
>>> Thanks,
>>> Enrico
>>>> Hi Enrico,
>>>> the snippet bellow). Hope that it's working for you.
>>>> @Override
>>>> Best,
>>>> Ivan
>>>>> Hi all,
>>>>> menu.
>>>>> ToolItem?
>>>>> Thanks,
>>>>> Enrico
Re: Popup menu doesn't work on ToolBar in CTabFolder top-right [message #93045 is a reply to message #93030] |
Thu, 12 June 2008 09:01 |
--------------040501060704080007080705
Hi Enrico,
here is the reworked complete code... please test it. You don't need
this in widgetSelected:
while (!m.isDisposed() && m.getVisible()) {
if (!d.readAndDispatch())
d.sleep();
m.dispose();
Hope this will help.
Best,
Ivan
> Hi Ivan,
> I've attached the class I use to reproduce the problem.
> Enrico
>> Hi Enrico,
>> Thanks,
>> Ivan
>>> Hi Ivan,
>>> 'null'
Re: Popup menu doesn't work on ToolBar in CTabFolder top-right [message #93105 is a reply to message #93045] |
Thu, 12 June 2008 12:19 |
Member |
Hi Ivan,
it works! Many thanks!
The code in widgetSelected comes from an old version of SWT, and it
continues to work in SWT 3.3 e 3.4 (RCP mode).
Because my application runs both in RCP and RAP the sources are shared,
except a little compatibility library.
I tested the code in both two modes and it works, so this is the final
solution.
Enrico
> Hi Enrico,
> d.sleep();
> m.dispose();
> Best,
> Ivan
>> Hi Ivan,
>> Thanks,
>> Enrico
>>> Hi Enrico,
>>> Thanks,
>>> Ivan
>>>> Hi Ivan,
>>>> );var wm = org.eclipse.swt.WidgetManager.getInstance();wm.dispose(
>>>> "w15" );wm.dispose( "w14" );wm.dispose( "w13"
>>>> Thanks,
>>>> Enrico
>>>>> Hi Enrico,
>>>>> Windows XP SP3.
>>>>> the exact snippet from my previous post?
>>>>> Best,
>>>>> Ivan
>>>>>> Hi Ivan,
>>>>>> for you?
>>>>>> please?
>>>>>> Thanks,
>>>>>> Enrico
>>>>>>> Hi Enrico,
>>>>>>> @Override
>>>>>>> Best,
>>>>>>> Ivan
>>>>>>>> Hi all,
>>>>>>>> SWT.DROP_DOWN,
>>>>>>>> CTabFolder
>>>>>>>> menu.
>>>>>>>> (both IE7 and Firefox2.0) dumps a javascript error.
>>>>>>>> ToolItem?
>>>>>>>> Thanks,
>>>>>>>> Enrico
Current Time: Fri Apr 26 07:59:26 GMT 2024
Powered by FUDForum. Page generated in 0.04225 seconds
