Problems implementing XML Schema Editor in my RCP application [message #777399] |
Tue, 10 January 2012 12:16 |
David Gonzalez Messages: 24 Registered: January 2011 |
Junior Member |
Hello everybody,
I tried to implement the XML Schema Editor in my RCP application. At first it worked but the editor throws some exceptions I don't understand and some things don't work as expected.
When I open a .xsd-File with the XML Schema Editor in my application following exceptions occur:
Reference item find.ext not found for action null (4 times)
Reference item additions not found for action null (1 time)
Adding a new element works, changing the type doesn't. I select an element and in the properties view is a combo "Type" with the text "string" in it, but if I open the combo box there is no content to choose.
With a right click on the element I try to open "Set Type > New...". Again an exception:
at org.eclipse.wst.xsd.ui.internal.common.commands.SetTypeCommand.execute(SetTypeCommand.java:57)
at org.eclipse.gef.commands.CommandStack.execute(CommandStack.java:197)
at org.eclipse.wst.xsd.ui.internal.common.actions.SetTypeAction.run(SetTypeAction.java:46)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:498)
(just ask if you need more stacktrace)
Does anyone know what could be wrong? Which plugins are necessary to use the XML Schema Editor in an own RCP application?
Greets
[Updated on: Tue, 10 January 2012 12:17] Report message to a moderator
FUDForum. Page generated in 0.03052 seconds
