Re: Math formulas in a BIRT report [message #749996 is a reply to message #749498] |
Tue, 25 October 2011 15:10 |
Can you deploy the js file to a web server and use a http reference as a
test?
<script type="text/javascript"
src="http://localhost:8090/mywebapp/myjsfile.js"></script>
Jason
On 10/25/2011 4:55 AM, enricodallarosa65 wrote:
> Alexey, thanks for your reply.
> I build an example with jsMath and I made it work in Firefox, but the same code isn't processed by BIRT.
> I enclosed the file with test code.
> I tried for half a day, with no results...
Re: Math formulas in a BIRT report [message #752781 is a reply to message #752555] |
Wed, 26 October 2011 14:12 |
Yes I am pretty sure <style> tags in text elements are not added to the
html head, so inline styles is the way to go on text elements.
Jason
On 10/26/2011 8:36 AM, enricodallarosa65 wrote:
> Hi Jason,
> I tried from a local webserver, but it doesn't work.
> I think that BIRT html/js engine is not able to elaborate jsMath scripts.
> I take a sample html file and:
> 1. make it process by Firefox in order to have TeX converted to
> styles&fonts
> 2. copy the resulting html to BIRT
> I succeeded only if I modified the processed file putting inline the
> styles created on the fly.
> I'm thinking about pre processing html server side and afterwards
> modifying the results, moving styles definition from <style> ...
> </style> to inline.
> Maybe it's a too long way...
> enrico
FUDForum. Page generated in 0.03978 seconds
