Home » Newcomers » Newcomers » Eclipse Indigo with JDK 1.7(Is Eclipse Indigo supposed to be able to use Java 1.7?)
Eclipse Indigo with JDK 1.7 [message #717567] Sun, 21 August 2011 08:13 Go to next message
Yesterday, I uninstalled Eclipse Indigo. I then installed the new Java 1.7 (specificall, jdk-7-windows-x64.exe) on my 64-bit Windows 7 computer. I adjusted my path environment variable so it points to the new jdk 1.7. My regedit now shows Java 1.7 to be the current version of Java.
I then re-installed Eclipse Indigo. In Eclipse, when I go to Window/Preferences/Java/Compiler, the Compiler Compliance Level drop-down shows options 1.3, 1.4, 1.5, and 1.6, but not 1.7. If I compile a program with a string for a switch control expression (a new feature in Java 1.7), I get a compilation error.
Note:
When I use a different IDE (TextPad), I can compile and run my Java 1.7 program (the one with a string for a switch control expression).
I load Eclipse (successfully) using the command:
C:\eclipse\eclipse.exe -vm "c:\Program Files\Java\jdk1.7.0\bin\javaw" -vmargs -Xmx256M
1. Is Eclipse Indigo supposed to be able to use Java 1.7?
2. If yes, how can I get Eclipse to use Java 1.7?
3. If no, when will Eclipse be able to use java 1.7?
John
Re: Eclipse Indigo with JDK 1.7 [message #717585 is a reply to message #717567] Sun, 21 August 2011 10:16 Go to previous messageGo to next message
Java 7 support for Eclipse is not part of the Indigo release. To get the
current state of work you can
- download any 3.8.0 release (e.g. M1)
- or download a 3.7.1 M or RC
- or update JDT in your 3.7.0
For more details, refer to
- http://wiki.eclipse.org/JDT_Core/Java7
- http://wiki.eclipse.org/JDT/Eclipse_Java_7_Support_%28BETA%29
Michael
Re: Eclipse Indigo with JDK 1.7 [message #1803333 is a reply to message #717585] Wed, 27 February 2019 00:12 Go to previous messageGo to next message
Hi Michael,
I need one clarity from you like how we can give security in eclipse indigo.
ex: can we give securities like when we upload code files in eclipse it has to be encrypted because i need to give security to my project.is it possible to give it?
i.e after running tomcat server automatically all the code should be in encrypted format,,others cant use my project?is this possible?
please suggest me on this.
Best,
Anand
Re: Eclipse Indigo with JDK 1.7 [message #1803364 is a reply to message #717567] Wed, 27 February 2019 06:20 Go to previous message
Hi All,
Best,
Anand
Previous Topic:Code security in eclipse
Next Topic:index.xhtml not created
Current Time: Fri Jul 04 14:58:29 EDT 2025
Powered by FUDForum. Page generated in 0.09463 seconds
