Re: Validation Error "use" parmeter [message #74890 is a reply to message #74877] |
Fri, 11 July 2008 13:12 |
Ed Merks Messages: 33142 Registered: July 2009 |
Sam,
You can generally ignore validation constraints on the XSD and still get
a Ecore model from it. Ecore doesn't have this constraint so the result
should be valid.
Sam wrote:
> Hi Ed,
> Thanks for the expalnation.
> Do you think, that generating a ecore from this "invalid" Schema will
> cause problem for EMF? Once i produce ECORE this should be Valid, or?
> Cheers,
> Sam
Ed Merks
Re: Validation Error "use" parmeter [message #603129 is a reply to message #74844] |
Fri, 11 July 2008 11:42 |
--------------030901090302080706000002
Sam,
See the second constraint for
http://www.w3.org/TR/xmlschema-1/#src-attribute
If you think about it, if the attribute must be present in the XML
instance, a default value is pointless because in a valid instance a
default will never be needed given an actual value will/must be present
Probably in the older version you were using a different validator that
didn't check this constraint properly.
Sam wrote:
> Hello!
> <xsd:element default="name" name="simpleTypContainsEnumeration"
> type="Nacl:simpleTypContainsEnumerationType" use="required"/>
> ERROR: The "use" Value must be optinal when default is present.
> Why? i work with the same Schema under Eclipse 3.3, the Validation
> Problem occure only when I use Ganymede (3.4)
> for your Comment i will be Thankful!
> Sam
<html>
<head>
http-equiv="Content-Type">
</head>
Sam,<br>
<br>
See the second constraint for<br>
<blockquote><a href="http://www.w3.org/TR/xmlschema-1/#src-attribute">http://www.w3.org/TR/xmlschema-1/#src-attribute</a><br>
</blockquote>
default will never be needed given an actual value will/must be present<br>
<br>
didn't check this constraint properly.<br>
<br>
<br>
Sam wrote:
<blockquote
cite="mid:4bdf374ce7ae50c1729234b12ba52fd0$1@www.eclipse.org"
type="cite">Hello!
<br>
<br>
<br>
<br>
<br>
<br>
Problem occure
Ed Merks
Re: Validation Error "use" parmeter [message #603141 is a reply to message #74877] |
Sam,
should be valid.
Sam wrote:
> Hi Ed,
> Cheers,
> Sam
Ed Merks
FUDForum. Page generated in 0.03624 seconds
