Home » Eclipse Projects » Sapphire » Sapphire Snippets
Sapphire Snippets [message #702276] Tue, 26 July 2011 03:10 Go to next message
Stathis Alexopoulos is currently offline Stathis Alexopoulos
Member
I am trying to evaluate Sapphire, and i am wondering if it is possible to work with it as a simple JFace application.
For example, is it possible to create some snippet like the following?
public static void main (String [] args)
Display display = new Display ();
Shell shell = new Shell (display);
shell.setLayout( new FillLayout());
IFileBugReportOp op = IFileBugReportOp.TYPE.instantiate();
IBugReport report = op.getBugReport();
SapphireDialog dialog = new SapphireDialog( shell, report,
"org.eclipse.sapphire.samples/org/eclipse/sapphire/samples/ezbug/EzBug.sdef!bug.report.dialog" );
if( dialog.open() == Dialog.OK )
// Do something. User input is found in the bug report model.
shell.pack ();
shell.open ();
while (!shell.isDisposed ())
if (!display.readAndDispatch ()) display.sleep ();
display.dispose ();
Re: Sapphire Snippets [message #702641 is a reply to message #702276] Tue, 26 July 2011 11:49 Go to previous message
Konstantin Komissarchik is currently offline Konstantin Komissarchik
Currently, the primary target for Sapphire is Eclipse IDE, although you should be able to use it in Eclipse RCP environment. Support for plain SWT/JFace environment (no OSGi, no workbench, etc.) is planned for future releases.
- Konstantin
Previous Topic:Sapphire on Eclipse Marketplace
Next Topic:JAXenter interview regarding Java EE Config Editors project
Current Time: Wed May 22 08:08:22 EDT 2013
Powered by FUDForum. Page generated in 0.01439 seconds
