Home » Language IDEs » C / C++ IDE (CDT) » debugging and global variables
debugging and global variables [message #71814] Wed, 28 May 2003 04:41 Go to next message
Originally posted by: xetor.gmx.net
Hallo,
1) it is possible to watch a global variable in the debug perspective
in the variable view (if I go with the cursor to the global variable
the content was showed in the source view, but this is not so good for
complex structs)?
2) can I access the gdb direct via the console to interact with the gdb
manualy?
3) in the debug perspective is the expressions view avaible with the
feature
add global varialbe, but it dosnt work! help?
(I use Eclipse Version: 2.1.0, CDT 1.1.0 Build 2003.05.15, MinGW 2.0.0-3,
gcc-3.2.2-20030208-1 and gdb-5.2.1-20021009)
thanks
harald
Re: debugging and global variables [message #71943 is a reply to message #71814] Wed, 28 May 2003 11:33 Go to previous messageGo to next message
Originally posted by: mikhailk.qnx.com
"harald" <xetor@gmx.net> wrote in message news:bb1sno$g2j$1@rogue.oti.com...
> Hallo,
> complex structs)?
The "Variables" view displays only local variables and arguments for the
selected stack frame.
You can use the "Add Expression (C/C++)" option to add a global variable to
the "Expressions" view.
> manualy?
Yes, you can. Use the "Show Debugger Console" option to switch to gdb
console. It doesn't have a gdb prompt but you can type gdb commands in it.
> feature
The "Add Globals" option has not implemented for some platforms.
> thanks
> harald
Re: debugging and global variables [message #72107 is a reply to message #71943] Wed, 28 May 2003 15:27 Go to previous messageGo to next message
Originally posted by: xetor.t-online.de
Mikhail Khodjaiants wrote:
for wich platforms is the feature "Add Globals" implemented ?
> > Hallo,
> > complex structs)?
> > manualy?
> > feature
> > thanks
> > harald
Re: debugging and global variables [message #72125 is a reply to message #72107] Wed, 28 May 2003 15:44 Go to previous messageGo to next message
harald wrote:
Sorry for last wrote.
For wich platforms is the feature "Add Globals" implemented ?
I use W2K and Windows XP and I see a window "selection needed | Select
Variables" , but no variables are shown, but a global variable is used.
> > > Hallo,
> > > complex structs)?
> > > manualy?
> > > feature
> > > thanks
> > > harald
Re: debugging and global variables [message #72161 is a reply to message #72125] Wed, 28 May 2003 16:25 Go to previous messageGo to next message
This feature works for Linux and QNX Neutrino.
"harald" <xetor@t-online.de> wrote in message
news:bb33i3$ln9$1@rogue.oti.com...
> Thanks
> > > > Hallo,
perspective
variable
good for
> > > > complex structs)?
the
variable to
gdb
> > > > manualy?
it.
> > > > feature
2.0.0-3,
> > > > thanks
> > > > harald
Re: debugging and global variables [message #72303 is a reply to message #72161] Thu, 29 May 2003 04:11 Go to previous messageGo to next message
it is planed to port this feature to other platforms like win32 or HPUX ?
"Mikhail Khodjaiants" <mikhailk@qnx.com> schrieb im Newsbeitrag
news:bb362p$o7e$1@rogue.oti.com...
> > Thanks
> > > > > Hallo,
> perspective
> variable
> good for
> > > > > complex structs)?
> the
> variable to
the
> gdb
> > > > > manualy?
gdb
in
> it.
the
> > > > > feature
> 2.0.0-3,
> > > > > thanks
> > > > > harald
Re: debugging and global variables [message #72376 is a reply to message #72303] Thu, 29 May 2003 11:08 Go to previous message
news:bb4fhp$ivk$1@rogue.oti.com...
Yes, it is. But the problem is how to extract the globals. The current
implementation is not reliable.
used.
> > > Thanks
> > > > > > Hallo,
> > perspective
> > variable
> > good for
> > > > > > complex structs)?
for
> > the
> > variable to
> the
> > gdb
> > > > > > manualy?
> gdb
commands
> in
> > it.
> the
> > > > > > feature
> > 2.0.0-3,
> > > > > > thanks
> > > > > > harald
Previous Topic:how do I install new version of CDT
Next Topic:Source builds of latest release?
Current Time: Sun Jul 06 11:02:34 EDT 2025
Powered by FUDForum. Page generated in 0.05388 seconds
