Home » Eclipse Projects » Remote Application Platform (RAP) » Virtual table and select all items problem
Virtual table and select all items problem [message #699258] Thu, 21 July 2011 04:01 Go to next message
Hi all,
I realize that this is most likely question to SWT group but let me
start with stating it here:
I have checkboxTableViewer(virtual). I added "select all" checkbox on
top. I use tableViewer#setAllChecked(boolean).
The problem is that only the preloaded table rows in the virtual table
are checked. If I scroll down the newly updated rows are not checked.
Do you know some solution to the described problem.
Thank you in advance,
Aleks
p.s.
I tried to write my own code to check the new rows but there is a
problem with the events order.
Re: Virtual table and select all items problem [message #699276 is a reply to message #699258] Thu, 21 July 2011 04:42 Go to previous messageGo to next message
Hi Aleks,
just compared the RAP/SWT TableItem#setChecked methods. I think that
this is a bug in RAP, because in SWT calling TableItem#setChecked cached
the item, but not in RAP.
Would you mind to open a bugzilla about it.
Ivan
On 7/21/2011 11:01 AM, Aleksandar Pavlov wrote:
> Hi all,
> Aleks
> p.s.
Re: Virtual table and select all items problem [message #699321 is a reply to message #699258] Thu, 21 July 2011 06:35 Go to previous messageGo to next message
Bug opened:
352722: [Table] TableItem#setChecked and TableItem#setGrayed don't cache
the virtual item
https://bugs.eclipse.org/bugs/show_bug.cgi?id=352722
> Hi all,
> Aleks
> p.s.
Re: Virtual table and select all items problem [message #699330 is a reply to message #699321] Thu, 21 July 2011 07:11 Go to previous messageGo to next message
Hi Ivan,
Do you accept source code contributions?
Aleks
On 21.7.2011 г. 13:35 ч., Ivan Furnadjiev wrote:
> Bug opened:
> the virtual item
>> Hi all,
>> Aleks
>> p.s.
Re: Virtual table and select all items problem [message #699343 is a reply to message #699330] Thu, 21 July 2011 07:45 Go to previous messageGo to next message
Hi Aleks,
sure... please attach a patch to the bug.
Ivan
On 7/21/2011 2:11 PM, Aleksandar Pavlov wrote:
> Hi Ivan,
> Aleks
>> Bug opened:
>> the virtual item
>>> Hi all,
>>> Aleks
>>> p.s.
Re: Virtual table and select all items problem [message #699375 is a reply to message #699343] Thu, 21 July 2011 09:00 Go to previous messageGo to next message
It appears to be rather simple solution as I see it.
I hope I didn't oversee something.
Hope that helps,
Aleks
On 21.7.2011 г. 14:45 ч., Ivan Furnadjiev wrote:
> Hi Aleks,
> Ivan
Re: Virtual table and select all items problem still valid [message #699861 is a reply to message #699375] Fri, 22 July 2011 09:38 Go to previous messageGo to next message
Hi Ivan,
I am sorry but oversaw i huge bit. The patch does not load the new table
rows checked. It was the fix attempt in my project that did that. I
think the bug is still valid, unless you have seen it working at your side.
I think of modifying the controls demo with 'select all' button for
testing such behavior.
Any suggestions?
Deep regrets,
Aleks
Re: Virtual table and select all items problem still valid [message #699868 is a reply to message #699861] Fri, 22 July 2011 09:59 Go to previous messageGo to next message
Hi Aleks,
did you check your code in RCP? Does it work there? If you could provide
a patch for Controls Demo that demonstrate the problem will be great. If
your code works in RCP fill free to open a bugzilla and attach the
Controls Demo demonstration patch there.
Best,
Ivan
On 7/22/2011 4:38 PM, Aleksandar Pavlov wrote:
> Hi Ivan,
> Any suggestions?
> Deep regrets,
> Aleks
Re: Virtual table and select all items problem still valid [message #699905 is a reply to message #699861] Fri, 22 July 2011 10:43 Go to previous messageGo to next message
Hi Aleks,
just checked in RCP and the behavior is the same with RAP - on
CheckboxTableViewer#setAllChecked( true ) only visible items are checked.
The code:
public void setAllChecked(boolean state) {
TableItem[] children = getTable().getItems();
for (int i = 0; i < children.length; i++) {
TableItem item = children[i];
if (item.getData() != null) {
if (item.getChecked() != state)
item.setChecked(state);
set the checked state only for the items that item.getData() is not
null. Virtual (hidden) items have null data.
HTH,
Ivan
> Hi Ivan,
> Any suggestions?
> Deep regrets,
> Aleks
Re: Virtual table and select all items problem still valid [message #701656 is a reply to message #699905] Mon, 25 July 2011 07:36 Go to previous messageGo to next message
Hi Ivan,
Thank you for the info.
Interesting, I reproduced different behavior:
In single-sourced project I added CheckBoxTableViewer in a view with
data- and label- providers and 150 entries.
The result in RAP is consistent (the bug discussed) but in RCP different
thing happens (find the attached screen shot):
All table rows are checked but the rows are not updated with contents on
scroll down.
So what do we do with this problem?
- I send the single sourced demo project to see if I abuse the API somehow;
- I write a 'select all' button in the RAP Controls demo in order to
reproduce and verify the bug;
- We ask RPC to fix that bug;
- We fix the bug and propose solution to RCP;
I am out of ideas.
I will be glad to help you out with this issue,
Aleks
On 22.7.2011 г. 17:43 ч., Ivan Furnadjiev wrote:
> Hi Aleks,
> The code:
> HTH,
> Ivan
Re: Virtual table and select all items problem still valid [message #701810 is a reply to message #701656] Mon, 25 July 2011 12:08 Go to previous messageGo to next message
Hi Aleks,
could you attach your single sourced demo project and the Controls Demo
changes here?
Best,
Ivan
On 7/25/2011 2:36 PM, Aleksandar Pavlov wrote:
> Hi Ivan,
> scroll down.
> I am out of ideas.
> Aleks
>> Hi Aleks,
>> The code:
>> for (int i = 0; i< children.length; i++) {
>> HTH,
>> Ivan
Re: Virtual table and select all items problem still valid [message #702589 is a reply to message #701810] Tue, 26 July 2011 10:42 Go to previous message
Hi Ivan,
Sure, I attach zip archive with the single-sourced demo.
I have no progress modifying the RAP demo, as it does not use
CheckboxTableViewer.
Hope that helps,
Aleks
On 25.7.2011 г. 19:08 ч., Ivan Furnadjiev wrote:
> Hi Aleks,
> changes here?
> Best,
> Ivan
Previous Topic:[GEF] Thumbnail + direct edit issues
Next Topic:New RAP timeout message
Current Time: Tue Jul 01 03:51:26 EDT 2025
Powered by FUDForum. Page generated in 0.09203 seconds
