Re: Any way of referencing multiple datasets from a report object? [message #70912 is a reply to message #70891] |
Thu, 01 September 2005 21:02 |
Marko,
You could always override the create method for the control and make a POJO
call or use another Data set that will set a global variable.
Jason Weathersby
BIRT PMC
"Marko" <mmilicevic@pssd.com> wrote in message
news:df7pc6$fal$1@news.eclipse.org...
> For a table i would like to display dynamic query data in the header. For
> example, i have a column labeled with a month of the year and the number
> of
> "selling days" for that month (ie. "January (21)"). The value 21 needs to
> come from a database query that is independent of the dataset used to
> render
> the rows. Any ideas? Is there a technical reason why only one dataset
> can
> be used per table?
> A similar issue exists for the text widget. I would like to have the
> ability to display data from multiple resultsets. I have had to resort to
> creating an additional dataset to join all the data needed by text widget.
> It works, but i would rather use the existing set of datasets.
Re: Any way of referencing multiple datasets from a report object? [message #71560 is a reply to message #71404] |
Fri, 02 September 2005 19:04 |
Marko,
Attached is a report that creates two data sets.
One for offices and one for orders.
In the reports initialize method I create a global variable test.
I add two tables to the report one for each data set.
I set the visibility of the offices one to hide, this is so the query gets
called. In the offices data set methods I override the onFetch method to
set my global variable to
test = row["OFFICECODE"];
Then in the second table I set the header value to the global variable test.
There are probally better ways to do this, but here it is.
Jason Weathersby
BIRT PMC
news:dfa1r3$9vi$1@news.eclipse.org...
> Thanks Jason. Can you point me to any sample code that demonstrates
> building another dataset from script? Presumably i create new dataset
> from
> a datasource? I don't see where the object model support this?
> Thank you.
> "Jason Weathersby" <jweathersby@actuate.com> wrote in message
> news:df7q8f$gel$1@news.eclipse.org...
>> Marko,
> POJO
>> Jason Weathersby
>> BIRT PMC
> For
>> > number
>> > of
> to
>> > render
>> > can
>> > be used per table?
> to
> widget.
FUDForum. Page generated in 0.04004 seconds
