Home » Language IDEs » ServerTools (WTP) » Code Hinting on JSP with Custom Tags (taglib)
icon5.gif  Code Hinting on JSP with Custom Tags (taglib) [message #675432] Tue, 31 May 2011 10:08 Go to next message
I'm developing a JSP tag that have an attribute that works with a set of possible values.
I don't need to enforce this values, but I would like the IDE do some code hinting or auto-completion.
Suppose a tag like this:
<mytag:sometag someattribute="value" />
The attribute someattribute can have any value (remember, I don't need to enforce), but I would like it to suggest you the following list of values: ValueA, ValueB and ValueC
Is there a way to do it?
Re: Code Hinting on JSP with Custom Tags (taglib) [message #675641 is a reply to message #675432] Wed, 01 June 2011 00:41 Go to previous messageGo to next message
> possible values.
Not without writing plug-ins. They would need to make judicious use of
the org.eclipse.wst.xml.core.modelQueryExtensions extension point.
Unless adding the values to the JSP->Editor->Templates preference page
in the JSP Attribute Value context is good enough.
Nitin Dahyabhai
Eclipse WTP Source Editing and JSDT
IBM Rational
Re: Code Hinting on JSP with Custom Tags (taglib) [message #675756 is a reply to message #675641] Wed, 01 June 2011 08:18 Go to previous messageGo to next message
Thank you, Nitin.
I don't think that templates can solve the problem as I have more than 1.000 possible values for one tag, and I have many tags...
About the plugin, I'll need to write one, right?
Don't you know any one that I could use??
Re: Code Hinting on JSP with Custom Tags (taglib) [message #675868 is a reply to message #675756] Wed, 01 June 2011 14:57 Go to previous messageGo to next message
Yes, you would have to write one. No, I'm not aware of anything that already does this--not that I've been looking, mind you.
Re: Code Hinting on JSP with Custom Tags (taglib) [message #676086 is a reply to message #675868] Thu, 02 June 2011 11:13 Go to previous message
Thank you, again, Nitin.
So, guess that I'll have to write a plugin.
I'll think of something...
Previous Topic:@XmlSchema for a metro webservice
Next Topic:[SOLVED] Problem Creating a Tomcat 6 Localhost Server Project
Current Time: Wed Jul 02 17:36:51 EDT 2025
Powered by FUDForum. Page generated in 0.05271 seconds
