| Eclipse Helios / Remote System Explorer issue [message #660551] |
Sat, 19 March 2011 05:33  |
Hi all,
I have a big problem with the latest Eclipse Helios and Remote System Explorer. RSE seems to crash after trying to open a file on a remote system. The error log says nothing else than the following:
!ENTRY org.eclipse.rse.ui 4 0 2011-03-19 10:06:00.021
!MESSAGE RSEF1002
The error message which pops up is the following:
Message reported from file system: The system cannot find the specified path.
I thought an update would be the solution so I checked for new updates and was prompted to install "Eclipse IDE for PHP Developers 1.3.2.20110301-1807". Unfortunately, the update fails with the following error:
!ENTRY org.eclipse.equinox.p2.engine 4 4 2011-03-19 10:24:16.095
!MESSAGE An error occurred while uninstalling
!SUBENTRY 1 org.eclipse.equinox.p2.engine 4 0 2011-03-19 10:24:16.095
!MESSAGE session context was:(profile=epp.package.php, phase=org.eclipse.equinox.internal.p2.engine.phases.Uninstall, operand=[R]org.eclipse.cvs_root 1.1.101.R35x_v20100125-7E79FGD9kKF67BPDZ7PKCE1911 --> null, action=org.eclipse.equinox.internal.p2.touchpoint.natives.actions.CleanupzipAction).
!SUBENTRY 1 org.eclipse.equinox.p2.touchpoint.natives 4 0 2011-03-19 10:24:16.095
!MESSAGE Backup of file D:\Program Files\eclipse\epl-v10.html failed.
!STACK 0
java.io.FileNotFoundException: C:\Users\Asus\AppData\Local\Temp\epp.package.php_25d9adbc7420_c0a8b215c63e\D\Program Files\eclipse\epl-v10.html (The system cannot find the specified path)
at java.io.FileOutputStream.open(Native Method)
at java.io.FileOutputStream.<init>(Unknown Source)
at org.eclipse.equinox.internal.p2.touchpoint.natives.BackupStore.backup(BackupStore.java:253)
at org.eclipse.equinox.internal.p2.touchpoint.natives.LazyBackupStore.backup(LazyBackupStore.java:36)
at org.eclipse.equinox.internal.p2.touchpoint.natives.actions.CleanupzipAction.cleanupzip(CleanupzipAction.java:85)
at org.eclipse.equinox.internal.p2.touchpoint.natives.actions.CleanupzipAction.execute(CleanupzipAction.java:30)
at org.eclipse.equinox.internal.p2.engine.ParameterizedProvisioningAction.execute(ParameterizedProvisioningAction.java:35)
at org.eclipse.equinox.internal.p2.engine.Phase.mainPerform(Phase.java:149)
at org.eclipse.equinox.internal.p2.engine.Phase.perform(Phase.java:78)
at org.eclipse.equinox.internal.p2.engine.PhaseSet.perform(PhaseSet.java:44)
at org.eclipse.equinox.internal.p2.engine.Engine.perform(Engine.java:73)
at org.eclipse.equinox.internal.p2.engine.Engine.perform(Engine.java:44)
at org.eclipse.equinox.p2.operations.ProvisioningSession.performProvisioningPlan(ProvisioningSession.java:174)
at org.eclipse.equinox.p2.operations.ProfileModificationJob.runModal(ProfileModificationJob.java:79)
at org.eclipse.equinox.p2.operations.ProvisioningJob.run(ProvisioningJob.java:177)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54)
RSE and Eclipse were working fine some days ago and I didn't change anything on my set-up. Now I can't even open 1 single file as "the specified path cannot be found".
Could it be a Java or Windows update causing these recent errors? I'm using Windows Vista.
I have also tried a completely fresh install of Helios and RSE, added some remote systems and tried to open files. The problem even persists there!
Can anybody please help me? I have already spend 2 days now searching for solutions but this problem doesn't seem to be pretty common.
Please let me know whether any more information is needed.
Thank you so much in advance!
I'm really helpless at the moment.
[Updated on: Sat, 19 March 2011 05:56] by Moderator
| Re: Eclipse Helios / Remote System Explorer issue [message #660621 is a reply to message #660620] |
Sat, 19 March 2011 21:57  |
Dear Toshihiro,
thank you very much for your reply.
Unfortunately, the remote log doesn't say anything meaningful except for the log entries I have already posted.
Or did I miss any additional log files other than the ".log" file directly in my workspace root?
The remote systems all throw out the same error message (RSEF1002) - no matter what connection type (in my case FTP and SSH) and remote system OS (in my case Windows and Linux).
It might be a permission issue on my Vista machine but I'm really stuck because I already tried every location possible (D:\eclipse, C:\eclipse, D:\Program Files\eclipse etc). I still cannot use RSE any more.
BTW, if that's helpful, here is my eclipse.ini file:
-startup
plugins/org.eclipse.equinox.launcher_1.1.1.R36x_v20101122_1400.jar
--launcher.library
plugins/org.eclipse.equinox.launcher.win32.win32.x86_1.1.2.R36x_v20101222
-showsplash
org.eclipse.platform
--launcher.XXMaxPermSize
256m
--launcher.defaultAction
openFile
-product
org.eclipse.epp.package.php.product
openFile
256M
-vm
C:/Program Files/Java/jdk1.6.0_24/bin/javaw.exe
-vmargs
-Dosgi.requiredJavaVersion=1.5
-Xms40m
-Xmx384m
Please excuse using the wrong forum. Could a moderator please move it to the correct one then?
PS: Starting up Eclipse with "-clean -vmargs -Dosgi.locking=none" doesn't work either. I'm always provided with the following error:
Locking is not possible in the directory "D:\Program Diles\eclipse\configuration\org.eclipse.osgi". A common reason is that the file system or Runtime Environment does not support file locking for that location. Please choose a different location, or disable file locking passing "-Dosgi.locking=none" as a VM argument.
Unable to create lock manager.
So maybe there's indeed a permission issue with Vista?
Thank you very much in advance!
FUDForum. Page generated in 0.04144 seconds
