Home » Eclipse Projects » JFace » Input Dialog - Textarea
Input Dialog - Textarea [message #650558] Tue, 25 January 2011 09:19 Go to next message
I need a dialog for simple textinput.
The text could be relative long, so I need a bigger textarea than the one row taxtarea of the Input Dialog.
Can I make that textarea bigger, or do I have to write my own Dialog?
If so, how do i create a bigger textarea?
Thanks in advance.
Re: Input Dialog - Textarea [message #650641 is a reply to message #650558] Tue, 25 January 2011 14:29 Go to previous message
You don't have to: the InputDialog is meant to be subclassed. Smile
Here is what I'd write it if I didn't have to fear anybody ever reading the code:
        InputDialog dlg = new InputDialog(Display.getCurrent().getActiveShell(), "Test", "Please input text.",
            "Test-Text", null) {
           * Override this method to make the text field multilined
           * and give it a scroll bar. But...
          protected int getInputTextStyle() {
            return SWT.MULTI | SWT.BORDER | SWT.V_SCROLL;
           * ...it still is just one line high.
           * This hack is not very nice, but at least it gets the job done... ;o)
          protected Control createDialogArea(Composite parent) {
            Control res = super.createDialogArea(parent);
            ((GridData) this.getText().getLayoutData()).heightHint = 100;
            return res;
        dlg.open();
Previous Topic:[Databinding] Master-detail-binding and validators
Next Topic:[Drag and Drop] DnD within same TreeViewer
Current Time: Fri Sep 12 22:17:56 EDT 2025
Powered by FUDForum. Page generated in 0.08390 seconds
