Extra pivot model testing [message #650471] |
Tue, 25 January 2011 07:13 |
Ed Willink Messages: 7670 Registered: July 2009 |
The org.eclipse.ocl.examples.test.xtext.SerializeTests tests assert that
a variety of Ecore models in org.eclipse.ocl.examples.test.xtext.models
can be successfully converted:
Ecore->Pivot->OCLinEcore then OCLinEcore->Pivot->Ecore to produce what
EMF Compare considers to be the same model.
There are currently three known limitations:
- OCL text is pretty-printed so whitespace changes are reported.
- Upper and lower bounds on generic types are not supported.
- Multiplicity upperbound of -2 (mixed content) is not supported.
- Hidden opposites (untested) might make it forwards but not backwards
EReference.eKeys might work, but I have no example.
If you have any potentially challenging Ecore models, please run them
by adapting my extra SerializeTests below.
package org.eclipse.ocl.examples.test.xtext;
* Tests that check that an Ecore model can be serialized to OCLinEcore.
public class SerializeTests2 extends SerializeTests
public void testTemp() throws Exception {
doSerialize("temp");
public void testTemp3() throws Exception {
doSerialize("Temp3");
public void testTemp4() throws Exception {
doSerialize("Temp4");
public void testMy() throws Exception {
doSerialize("My");
You may want to wait till M5 to avoid the difficulties of piecing the
Xtext M4.5 contributions together.
Any 'good' failures I'd like to add to the test suite.
Ed Willink
FUDForum. Page generated in 0.04920 seconds
