Regenerated Enumerator [message #648932] |
Sat, 15 January 2011 19:10 |
AJ Messages: 77 Registered: July 2009 |
Member |
When I generated the model the first time, the enums were created like this:
P_AFT_MID_RING(1, "p_AftMidRing", "P-Aft (mid ring)"),
Now, if I try to re-generated the model, then it is generated like this:
PAFT_MID_RING(1, "p_AftMidRing", "P-Aft (mid ring)"),
Neither the Name or the Literal has changed so why is now removing the first underscore?
Re: Regenerated Enumerator [message #648936 is a reply to message #648932] |
Sat, 15 January 2011 19:39 |
Ed Merks Messages: 33142 Registered: July 2009 |
AJ,
I'll need a test case and steps for reproducing the problem. You might
want to put those all in a bugzilla.
> this:
> first underscore?
Ed Merks
FUDForum. Page generated in 0.02621 seconds
