Home » Modeling » EMF » [EMF Transaction] Problems running two read-only transactions at the same time
[EMF Transaction] Problems running two read-only transactions at the same time [message #648527] Thu, 13 January 2011 06:53 Go to next message
I have a very simple test case: a transactional editing domain, a single
resource, a single object. I start two threads that execute long running
loops as the following:
for (int i = 0; i < 1000; i++) {
editingDomain.runExclusive(runnable);
That's it. The runnable is simply asserting that the code is executed in
a transaction. However, in many cases this test fails with an exception:
java.lang.IllegalArgumentException: Can only deactivate the active
transaction
org.eclipse.emf.transaction.impl.TransactionalEditingDomainI mpl.deactivate(TransactionalEditingDomainImpl.java:533)
org.eclipse.emf.transaction.impl.TransactionImpl.close(Trans actionImpl.java:712)
org.eclipse.emf.transaction.impl.TransactionImpl.commit(Tran sactionImpl.java:474)
org.eclipse.emf.transaction.impl.TransactionalEditingDomainI mpl.runExclusive(TransactionalEditingDomainImpl.java:333)
It seems that the editing domain code is not able to handle multiple
read-only (and only read-only) transactions at the same time which isn't
what I would expect from the transaction framework.
Is there any mistake in my thoughts or is this a known issue or am I
missing something?
Thanks Jan
Re: [EMF Transaction] Problems running two read-only transactions at the same time [message #649024 is a reply to message #648527] Mon, 17 January 2011 04:20 Go to previous messageGo to next message
Small update: the problem only occurs when running the test case as
plain test (no eclipse runtime). When run as plugin test (within the
eclipse runtime) the code behaves as expected. I thought that EMF core
resp. eclipse transactions do not depend on an eclipse runtime?
Jan
> Thanks Jan
Re: [EMF Transaction] Problems running two read-only transactions at the same time [message #649097 is a reply to message #649024] Mon, 17 January 2011 11:17 Go to previous messageGo to next message
Jan,
I think transactions do depend on the workspace...
> Jan
>> Thanks Jan
Re: [EMF Transaction] Problems running two read-only transactions at the same time [message #649254 is a reply to message #649097] Tue, 18 January 2011 07:06 Go to previous message
Ed,
that would explain the behavior. Since I do not plan to run the real
code outside an eclipse runtime the issue is solved for me.
Thanks Jan
> Jan,
>> Jan
>>> Hi,
>>> Thanks Jan
Previous Topic:[CDO] URI of the resource ... does not match the nsURI ... of the top-level package
Next Topic:Compilation errors in generated code when using generic types with maps
Current Time: Fri Jul 25 21:18:39 EDT 2025
Powered by FUDForum. Page generated in 0.04072 seconds
