Re: [Acceleo 3] Internal Error - installBundle - NullPointerException [message #645686 is a reply to message #645683] |
Sun, 19 December 2010 21:50   |
Kirsten M. Z. Messages: 132 Registered: July 2010 |
Oh...
The more I try, the more errors I get. Right now, I am testing for 12 hours, and I still have no idea what's wrong.
I often get errors like "Structural feature 'lement' not found", "The feature 'lement' is not a valid feature" or "Structural feature 'uardian' not found". Yes, somehow the first letter of the feature gets swallowed (only experienced this with Acceleo 3.0.1).
However, I also get another very interesting error right now (sometimes). This error seems like a "meaningful error" (in contrast to the other ones). He tells me, that my class definition cannot be found (org/example/MyModelPackage). I cannot comprehend this error, because the file "org/example/MyModelPackage.class" exists. Its jar file is also in the build path of my Acceleo project. The according plug-in is also installed in my Eclipse environment. This is not enough? How is it possible, that he complains, that he cannot find the class definition?
java.lang.reflect.InvocationTargetException
at org.eclipse.jface.operation.ModalContext.run(ModalContext.java:421)
at org.eclipse.jface.dialogs.ProgressMonitorDialog.run(ProgressMonitorDialog.java:507)
at org.eclipse.ui.internal.progress.ProgressMonitorJobsDialog.run(ProgressMonitorJobsDialog.java:275)
at org.eclipse.ui.internal.progress.ProgressManager$5.run(ProgressManager.java:960)
at org.eclipse.ui.internal.progress.ProgressManager.busyCursorWhile(ProgressManager.java:995)
at org.eclipse.ui.internal.progress.ProgressManager.busyCursorWhile(ProgressManager.java:970)
at org.eclipse.ui.internal.progress.ProgressManager.run(ProgressManager.java:1166)
at org.eclipse.acceleo.module.sample17.ui.popupMenus.AcceleoGenerateSampleAction.run(AcceleoGenerateSampleAction.java:91)
at org.eclipse.ui.actions.ActionDelegate.runWithEvent(ActionDelegate.java:70)
at org.eclipse.ui.internal.PluginAction.runWithEvent(PluginAction.java:241)
at org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionItem.java:584)
at org.eclipse.jface.action.ActionContributionItem.access$2(ActionContributionItem.java:501)
at org.eclipse.jface.action.ActionContributionItem$5.handleEvent(ActionContributionItem.java:411)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4066)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3657)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2640)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2604)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2438)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:671)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:664)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:115)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:369)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:619)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:574)
at org.eclipse.equinox.launcher.Main.run(Main.java:1407)
at org.eclipse.equinox.launcher.Main.main(Main.java:1383)
Caused by: java.lang.NoClassDefFoundError: org/example/MyModelPackage
at org.eclipse.acceleo.module.sample17.files.Generate.registerPackages(Generate.java:252)
at org.eclipse.acceleo.engine.service.AbstractAcceleoGenerator.initialize(AbstractAcceleoGenerator.java:291)
at org.eclipse.acceleo.module.sample17.files.Generate.<init>(Generate.java:83)
at org.eclipse.acceleo.module.sample17.ui.common.GenerateAll.doGenerate(GenerateAll.java:88)
at org.eclipse.acceleo.module.sample17.ui.popupMenus.AcceleoGenerateSampleAction$1.run(AcceleoGenerateSampleAction.java:76)
at org.eclipse.jface.operation.ModalContext$ModalContextThread.run(ModalContext.java:121)
or
Caused by: java.lang.ClassNotFoundException: org/example/MyModelPackage
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:506)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:422)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:410)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(DefaultClassLoader.java:107)
... 6 more
[Updated on: Sun, 19 December 2010 21:58] Report message to a moderator
Re: [Acceleo 3] Internal Error - installBundle - NullPointerException [message #645733 is a reply to message #645686] |
Mon, 20 December 2010 09:52  |
--------------060807060900090900070603
Content-Type: text/plain; charset=UTF-8; format=flowed
I don't really know what you've tested, but you seem to mix multiple
things here...
First things first : if you are developping Eclipse plugins, you should
never have to play with the build path or jar files. When you need to
add a dependency to your project, you open the META-INF/MANIFEST.MF
file, open the "dependencies" tab, then add the dependency from there.
Adding the jar file to the build path will only get you obscure errors.
The first error you got (with the "installBundle" trace) means that your
generator project has a dependency towards another project of your
workspace ... which is not a plugin or which has invalid MANIFEST.MF or
plugin.xml artifacts.
If you follow the "getting started" for Acceleo, do you still get these
errors :
- Create a New -> Acceleo Project
- Add dependencies from the MANIFEST.MF to the required projects
- Copy/paste your generators in this 'clean' project
- Try and launch the generation
Laurent Goubet
Obeo
On 19/12/2010 22:50, vultur wrote:
> Oh... :cry:
> I often get errors like "Structural feature 'lement' not found" or
> at org.eclipse.jface.operation.ModalContext.run(ModalContext.ja va:421)
> at
> org.eclipse.jface.dialogs.ProgressMonitorDialog.run(Progress MonitorDialog.java:507)
> at
> org.eclipse.ui.internal.progress.ProgressMonitorJobsDialog.r un(ProgressMonitorJobsDialog.java:275)
> at
> org.eclipse.ui.internal.progress.ProgressManager$5.run(Progr essManager.java:960)
> at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:70)
> at
> org.eclipse.ui.internal.progress.ProgressManager.busyCursorW hile(ProgressManager.java:995)
> at
> org.eclipse.ui.internal.progress.ProgressManager.busyCursorW hile(ProgressManager.java:970)
> at
> org.eclipse.ui.internal.progress.ProgressManager.run(Progres sManager.java:1166)
> at
> org.eclipse.acceleo.module.sample17.ui.popupMenus.AcceleoGen erateSampleAction.run(AcceleoGenerateSampleAction.java:91)
> at
> org.eclipse.ui.actions.ActionDelegate.runWithEvent(ActionDel egate.java:70)
> at org.eclipse.ui.internal.PluginAction.runWithEvent(PluginActi on.java:241)
> at
> org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:584)
> at
> org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:501)
> at
> org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:411)
> at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
> at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:4066)
> at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3657)
> at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2640)
> at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:24 38)
> at
> org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:332)
> at
> org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:664)
> at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:149)
> at
> org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:115)
> at
> org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:196)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
> at
> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:369)
> at
> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
> at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 619)
> at
> org.eclipse.acceleo.module.sample17.files.Generate.registerP ackages(Generate.java:252)
> at
> org.eclipse.acceleo.engine.service.AbstractAcceleoGenerator. initialize(AbstractAcceleoGenerator.java:291)
> at
> at
> org.eclipse.acceleo.module.sample17.ui.common.GenerateAll.do Generate(GenerateAll.java:88)
> at
> org.eclipse.acceleo.module.sample17.ui.popupMenus.AcceleoGen erateSampleAction$1.run(AcceleoGenerateSampleAction.java:76)
> at
> org.eclipse.jface.operation.ModalContext$ModalContextThread. run(ModalContext.java:121)
Content-Type: text/x-vcard; charset=utf-8;
name="laurent_goubet.vcf"
Content-Disposition: attachment;
filename="laurent_goubet.vcf"
YmVnaW46dmNhcmQNCmZuOkxhdXJlbnQgR291YmV0DQpuOkdvdWJldDtMYXVy ZW50DQpvcmc6
PGEgaHJlZj0iaHR0cDovL3d3dy5vYmVvLmZyIj5PYmVvPC9hPg0KZW1haWw7 aW50ZXJuZXQ6
bGF1cmVudC5nb3ViZXRAb2Jlby5mcg0KdXJsOmh0dHA6Ly93d3cub2Jlby5m cg0KdmVyc2lv
bjoyLjENCmVuZDp2Y2FyZA0KDQo=
--------------060807060900090900070603--
FUDForum. Page generated in 0.03056 seconds
