Remote hosted repository and bundle start [message #643579] |
Tue, 07 December 2010 14:13 |
Lorie Pisicchio Messages: 44 Registered: October 2010 |
Member |
Hi!
I try to configure a Virgo Web Server to be a hosted repository, and another one to have a remote repository. I followed the documentation as described here : http://www.eclipse.org/virgo/documentation/virgo-documentati on-2.1.0.RELEASE/docs/virgo-user-guide/htmlsingle/virgo-user -guide.html#configuring-hosted-repo
but it was not successful. The URI is not even reachable from a browser.
After a few tries, I finally decided to use the org.eclipse.virgo.apps.repository.properties to publish the repository. On the other Virgo instance, I declared a remote repository as declared in the doc. this time, it works. When VWS starts, I can read the message <RP0051I> The repository 'mos-remote' is available.
Is it normal that hosted repository configuration is in the **.apps.repository.** file? In this case, maybe the documentation is not up-to-date.
Then, I try to start a plan by droppping it into the pickup directory of VWS. The bundles included in the path are available on the other instance of Virgo, inside the hosted repository. The installation of the plan fails with the following error :
<DE0002E> Installation of plan 'mos-core.plan' version '3.0.0.SNAPSHOT' failed. java.lang.NullPointerException: null
at java.io.File.<init>(File.java:360)
at org.eclipse.virgo.kernel.install.artifact.internal.StandardInstallArtifactTreeInclosure.createInstallTree(StandardInstallArtifactTreeInclosure.java:102)
at org.eclipse.virgo.kernel.deployer.core.internal.PlanResolver.createInstallArtifactTree(PlanResolver.java:113)
at org.eclipse.virgo.kernel.deployer.core.internal.PlanResolver.operate(PlanResolver.java:70)
at org.eclipse.virgo.kernel.deployer.core.internal.PlanResolver.access$0(PlanResolver.java:62)
at org.eclipse.virgo.kernel.deployer.core.internal.PlanResolver$1.visit(PlanResolver.java:56)
at org.eclipse.virgo.util.common.ThreadSafeArrayListTree.visit(ThreadSafeArrayListTree.java:165)
at org.eclipse.virgo.kernel.deployer.core.internal.PlanResolver.transform(PlanResolver.java:53)
at org.eclipse.virgo.kernel.install.pipeline.stage.transform.internal.TransformationStage.doProcessTree(TransformationStage.java:55)
at org.eclipse.virgo.kernel.install.pipeline.stage.AbstractPipelineStage.process(AbstractPipelineStage.java:41)
at org.eclipse.virgo.kernel.install.pipeline.internal.StandardPipeline.doProcessTree(StandardPipeline.java:62)
at org.eclipse.virgo.kernel.install.pipeline.internal.CompensatingPipeline.doProcessTree(CompensatingPipeline.java:72)
at org.eclipse.virgo.kernel.deployer.core.internal.PipelinedApplicationDeployer.driveInstallPipeline(PipelinedApplicationDeployer.java:271)
at org.eclipse.virgo.kernel.deployer.core.internal.PipelinedApplicationDeployer.doInstall(PipelinedApplicationDeployer.java:151)
at org.eclipse.virgo.kernel.deployer.core.internal.PipelinedApplicationDeployer.install(PipelinedApplicationDeployer.java:123)
at org.eclipse.virgo.kernel.deployer.core.internal.PipelinedApplicationDeployer.deploy(PipelinedApplicationDeployer.java:190)
at org.eclipse.virgo.kernel.deployer.hot.HotDeploymentFileSystemListener.deploy(HotDeploymentFileSystemListener.java:174)
at org.eclipse.virgo.kernel.deployer.hot.HotDeploymentFileSystemListener.deployIfNotDeployed(HotDeploymentFileSystemListener.java:186)
at org.eclipse.virgo.kernel.deployer.hot.HotDeploymentFileSystemListener.onChange(HotDeploymentFileSystemListener.java:87)
at org.eclipse.virgo.util.io.FileSystemChecker.notifyListeners(FileSystemChecker.java:245)
at org.eclipse.virgo.util.io.FileSystemChecker.check(FileSystemChecker.java:166)
at org.eclipse.virgo.kernel.deployer.hot.WatchTask.run(WatchTask.java:58)
at java.lang.Thread.run(Thread.java:619)
If I shutdown the VWS hosting the repository, I get a "normal" error unable to satisfy dependency.
So I assume the bundles are found in the remote repository, but they can not start.
Can someone help with this error? How are the bundles supposed to be started? Will they be copied on the local VWS instance, and started there, or will they be started in the remote VWS and used over the network?
If the second option is the correct one, then how is the remote service invocation implemented?
Thanx in advance.
[Updated on: Fri, 10 December 2010 10:48] Report message to a moderator
Re: Remote hosted repository and bundle start [message #644281 is a reply to message #643579] |
Fri, 10 December 2010 11:32 |
Glyn Normington Messages: 1222 Registered: July 2009 |
Lorie Pisicchio wrote on Tue, 07 December 2010 14:13 | Hi!
This is a documentation bug. Well spotted! I have raised bug 332293 to fix this.
Thanx in advance.
The bundles are supposed to be copied to a cache in the work directory of the local VWS instance and then installed and started in the local VWS instance.
It seems that for some reason the file transfer is either not happening or is failing. You could have a dig around in the work directory to see if there are any clues.
Note that the remote repository index contains a hash of the bundle contents so that the copy in the cache (in the local VWS instance) can be checked for being up to date. Initially or if the hash in the index does not match the hash of the cached bundle (if there is one), we transfer the file from the remote repository to the cache. This transfer process uses HTTP, so I wonder if there is something unusual in your setup which is causing this problem.
Hope that helps. If the problem can be re-created and encapsulated in a bugzilla, please feel free to raise one.
Re: Remote hosted repository and bundle start [message #644778 is a reply to message #644626] |
Tue, 14 December 2010 08:36 |
The class HostedRepositoryUriMapper contains this:
String hostname = InetAddress.getLocalHost().getCanonicalHostName();
this.uriPrefix = String.format("http://%s:%s/org.eclipse.virgo.apps.repository/%s", hostname, port, repositoryName);
So the current behaviour of using host name instead of IP address in the remote repository index is hardcoded.
Please would you raise an enhancement bugzilla to record your requirement.
[Updated on: Tue, 14 December 2010 08:39] Report message to a moderator
FUDForum. Page generated in 0.06713 seconds
