Re: make all make: Nothing to be done for `all'. [message #641637 is a reply to message #641608] |
Fri, 26 November 2010 12:12 |
Axel Mueller Messages: 1973 Registered: July 2009 |
No Real Name wrote on Fri, 26 November 2010 10:41 | hi,
thanks for the reply..
i tried modifying the source file and rebuilt and once again it gave the same satement :
**** Build of configuration Default for project CPlusProj ****
make all
i must stress that this is a working/existing project i wrote in devc++ . i just want to learn how to import it to eclipse. Also, going by your answer, i decided to run it after building it and here it says :
Launched failed. binaries not found
This sounds like your makefile does indeed nothing. That's why launching will fail then.
Can you execute "make all" on the command line (outside Eclipse) and will it then build your project?
You should also be aware that you will get the above message if make does not find a Makefile! So probably you did not define the correct build location in project properties?
Before you ask
- search this forum
- see the FAQ http://wiki.eclipse.org/CDT/User/FAQ
- google
FUDForum. Page generated in 0.03595 seconds
