Re: disposing images created by a label provider [message #636732 is a reply to message #636671] |
Tue, 02 November 2010 15:19 |
Daniel Krügler Messages: 853 Registered: July 2009 |
On 02.11.2010 13:41, Luca Ferrari wrote:
> Hi, following the rule that if you create them, you must dispose them
> I'd like to dispose a set of images created in a label provider used
> within a table viewer. The problem is that the label provider do not
> provide a dispose method (implementing ITableLabelProvider), so I don't
> know how to do this, and using finalizers does not sound good to me.
> Maybe I'm doing wrong this, and instead of using the label provider to
> keep track of images I should use the ImageRegistry. Can anyone give me
> a clue of what is the right way of managing images required by a a label
> provider?
You are misinformed. Each label provider (including ITableLabelProvider)
has a dispose method from IBaseLabelProvider, which becomes
automatically called by the viewer, when it is disposed. We take
advantage of this feature in mayn of our label providers.
HTH & Greetings from Bremen,
Daniel Krügler
FUDForum. Page generated in 0.02944 seconds
