Home » Modeling » UML2 » Loading UML_21.ecore model from a standalone java app
Loading UML_21.ecore model from a standalone java app [message #628146] Tue, 22 December 2009 14:55 Go to next message
Hi All
I asked a question on the emf group that got redirected here.
Can anyone please help ?
http://www.eclipse.org/forums/index.php?t=msg&th=159731& amp;start=0&
Re: Loading UML_21.ecore model from a standalone java app [message #628147 is a reply to message #628146] Wed, 23 December 2009 10:49 Go to previous messageGo to next message
Hi Dameer,
Have you looked here?
http://wiki.eclipse.org/MDT/UML2/FAQ#What.27s_required_to_lo ad_a_UML_.28.uml.29_resource_from_a_standalone_application.3 F
You will also need to register the UML 212 namespace:
resourceSet.getPackageRegistry().put(UML212UMLResource.UML_M ETAMODEL_NS_URI,
UMLPackage.eINSTANCE);
Hope that helps,
---Tim---
Dameer Joog wrote:
> Hi All
Re: Loading UML_21.ecore model from a standalone java app [message #628148 is a reply to message #628147] Wed, 23 December 2009 06:13 Go to previous messageGo to next message
Sorry to ask this newbie question but i am not loading a .uml file. I am trying to load the uml2 ecore metamodel which is UML_21.ecore.
Also it looks like i have to put some jar files in the class path for my application to run now. Can you say which ones i need ?
maybe org.eclipse.uml2.uml.resources_<version>.jar but what else since its not mentioned in the faq ?
Thanks a lot.
Re: Loading UML_21.ecore model from a standalone java app [message #628151 is a reply to message #628146] Tue, 29 December 2009 13:03 Go to previous message
I tried to follow uml2 standlone faq but i am still getting the getEPackage() as null on one class only (EmodelElement).
EmodelElement is a superclass of the ELement class.
EPackage currPackage = superType.getEClassifier().getEPackage();
this always returns null for the Element class superclass EmodelElement as i expalined in the emf group.
I am starting to think that this maybe has nothing to do with uml.
output----------------------
[java] Loading metamodel ... uml
[java] class Comment {
[java] }
[java] class Element {
[java] eClass proxy:false
[java] superType proxy:false
[java] classifier proxy:true
parser-----------------
//EGenericType superType=null;
System.out.println(" class " + eClass.getName() +" {");
for (EGenericType superType : eClass.getEGenericSuperTypes()) {
//String typeName = getTypeName(superType, eClass);
if(currPackage==null){
System.out.println("eClass proxy:"+eClass.eIsProxy());
System.out.println("superType proxy:"+superType.eIsProxy());
System.out.println("classifier proxy:"+superType.getEClassifier().eIsProxy());
}else {
uml2------------
protected void loadUml2MetaModel(ResourceSet resourceSet) {
EPackage.Registry reg1;
reg1 = resourceSet.getPackageRegistry();
reg1.put(UMLPackage.eNS_URI, UMLPackage.eINSTANCE);
reg1.put(UML212UMLResource.UML_METAMODEL_NS_URI, UMLPackage.eINSTANCE);
Factory.Registry reg2;
reg2 = resourceSet.getResourceFactoryRegistry();
reg2.getExtensionToFactoryMap().put(UMLResource.FILE_EXTENSI ON,
UMLResource.Factory.INSTANCE);
Map<URI, URI> uriMap = resourceSet.getURIConverter().getURIMap();
URI uri = URI
.createURI(" jar:file:./lib/ecore/org.eclipse.uml2.uml.resources_3.0.0.v2 00906011111.jar!/ ");
uriMap.put(URI.createURI(UMLResource.LIBRARIES_PATHMAP), uri
.appendSegment("libraries").appendSegment(""));
uriMap.put(URI.createURI(UMLResource.METAMODELS_PATHMAP), uri
.appendSegment("metamodels").appendSegment(""));
uriMap.put(URI.createURI(UMLResource.PROFILES_PATHMAP), uri
.appendSegment("profiles").appendSegment(""));
Previous Topic:Loading UML_21.ecore model from a standalone java app
Next Topic:Abstraction, mapping reference is typed OpaqueExpression and not Expression
Current Time: Wed Jul 02 16:29:47 EDT 2025
Powered by FUDForum. Page generated in 0.05793 seconds
