Home » Archived » Eclipse Communications Framework (ECF) » docshare and internal openfire xmpp server
Re: docshare and internal openfire xmpp server [message #624782 is a reply to message #624777] |
Sat, 18 April 2009 18:06 |
Originally posted by: marc.esher.comcast.net
So I decided to go back and try this again after this newsgroup thread got a
bump, and I was able to get docshare working successfully over XMPP on an
internal openfire server. However, I ran into some bumps and I'm wondering
if possibly this could be fixed by a small change to ECF.
First, our servers at work have names like "blahblahWeb05"... almost all end
in numbers. our internal domain is ugly, too. so a server's fully qualified
name ends up being something like blahWeb05.bsg.something.ad.com
I set up openfire on Web05, and tried to connect to it from within eclipse
using XMPP with a username like mesher@Web05. this doesn't work becuase the
wizard won't allow server names ending in numbers. So I then tried
mesher@Web05.bsg.something.ad.com and this allowed me to connect. Using
this, I was able to get docshare working, almost. I could successfully share
a file, and the recipient would see my changes. But if the recipient changed
the file, the changes would not be reflected on my end. This appears related
to the naming stuff discussed in that bug; however, when I'd change the
server name in openfire's config to be web05.bsg.something.ad.com instead of
just web05, it would revert back to web05 after restarting openfire. I do
not know what that's about. Consequently, I wasn't able to get docshare
working completely successfully on a server with this numeric naming.
Then, I set up openfire on the one server I could find in our office that
didn't end numerically. i was able to successfully connect to it within
eclipse using mesher@bltrserver, and docshare worked perfectly, without the
need for the full domain.
Now, this leads me to suspect that if the wizard would just let me use the
Web05 server, without the domain, that I wouldn't ahve any issues at all on
the original server I tried.
Thus, my suggestion is to change XMPPConnectWizardPage's emailPattern from
this:
..+@.+.[a-z]+(:[0-9]+)?
to this:
..+@.+.[a-z0-9]+(:[0-9]+)?
which would allow servernames like mine to be accepted by the wizard page.
What do you think?
Marc
"Scott Lewis" <slewis@composent.com> wrote in message
news:49E6A377.7030000@composent.com...
> Hi Scott,
> Scott Selvia wrote:
> <stuff deleted>
>> I made those changes to the openfire server and did a restart and now
>> both parties can edit a document and see the other persons changes.
> That's great to hear.
>> The only issue we have at this point is the chat room...When we try to
>> enter a chat room we get the following:
>> Could not connect to <chat room name>
>> Error is Exception joining %1
>> Hope this helps... and any info on the chat room would be great!!!!
> We've not seen any difficulties such as this in entering the chat
> room...at least with our OpenFire server. One thing to check...that all
> the chat room permissions are set (i.e. no password for entry, etc), and
> that it's a public chat room.
> If you continue to have problems please report this as a bug to
> https://bugs.eclipse.org/bugs/enter_bug.cgi?product=ECF
> ...and if you have the stack information from the Error log (and/or
> information that goes into the Wildfire server log when the failure
> occurs) please include it in the bug report as well.
> Thanks.
> Scott
>> news:4964D746.5030502@composent.com...
>>> Hi Marc,
>>> Some have seen some issues with other xmpp servers before...e.g.
>>> https://bugs.eclipse.org/bugs/show_bug.cgi?id=237901
>>> but I don't think we've seen anything with xmpp server...except perhaps
>>> some configuration issues. Could others comment if they've seen
>>> something like this with their XMPP server? I recall something on the
>>> newsgroup or ecf-dev mailing list about needing a domain name (rather
>>> than just IP address) for the openfire server, but I'm not confident
>>> this is right.
>>> So could others that use openfire perhaps speak up here. I'll also look
>>> at the newsgroup and mailing list archive.
>>> Scott
>>> Marc Esher wrote:
>>>> Greetings.
>>>> I've set up an internal openfire xmpp server, set up users, have it all
>>>> hooked up with eclipse.
>>>> when I try to share documents via Share Editor With.... nothing
>>>> happens. The "Stop Sharing" context menu item does appear, but the file
>>>> never gets shared to the other user.
>>>> Can anyone tell me if there's something I need to set up in openfire to
>>>> get this working? the PDE error log isn't showing me anything
>>>> suspicious.
>>>> thanks!
>>>> marc
Re: docshare and internal openfire xmpp server [message #624850 is a reply to message #624782] |
Mon, 20 April 2009 14:34 |
Scott Lewis Messages: 1038 Registered: July 2009 |
Hi Marc,
This suggestion seems completely reasonably to me. Would you mind
opening a bug for this?...and we'll attempt to get to it as quickly as
possible.
Scott
> got a bump, and I was able to get docshare working successfully over
> XMPP on an internal openfire server. However, I ran into some bumps and
> I'm wondering if possibly this could be fixed by a small change to ECF.
> end in numbers. our internal domain is ugly, too. so a server's fully
> qualified name ends up being something like blahWeb05.bsg.something.ad.com
> eclipse using XMPP with a username like mesher@Web05. this doesn't work
> becuase the wizard won't allow server names ending in numbers. So I then
> tried
> Using this, I was able to get docshare working, almost. I could
> successfully share a file, and the recipient would see my changes. But
> if the recipient changed the file, the changes would not be reflected on
> my end. This appears related to the naming stuff discussed in that bug;
> however, when I'd change the server name in openfire's config to be
> web05.bsg.something.ad.com instead of just web05, it would revert back
> to web05 after restarting openfire. I do not know what that's about.
> Consequently, I wasn't able to get docshare working completely
> that didn't end numerically. i was able to successfully connect to it
> within eclipse using mesher@bltrserver, and docshare worked perfectly,
> without the need for the full domain.
> the Web05 server, without the domain, that I wouldn't ahve any issues at
> all on the original server I tried.
> from this:
> to this:
> What do you think?
> Marc
>> Hi Scott,
>> Scott Selvia wrote:
>> <stuff deleted>
>>> to enter a chat room we get the following:
>> all the chat room permissions are set (i.e. no password for entry,
>> etc), and that it's a public chat room.
>> Thanks.
>> Scott
>>>> Hi Marc,
>>>> perhaps some configuration issues. Could others comment if they've
>>>> seen something like this with their XMPP server? I recall something
>>>> on the newsgroup or ecf-dev mailing list about needing a domain name
>>>> (rather than just IP address) for the openfire server, but I'm not
>>>> confident this is right.
>>>> look at the newsgroup and mailing list archive.
>>>> Scott
>>>> Marc Esher wrote:
>>>>> Greetings.
>>>>> all hooked up with eclipse.
>>>>> file never gets shared to the other user.
>>>>> openfire to get this working? the PDE error log isn't showing me
>>>>> anything suspicious.
>>>>> thanks!
>>>>> marc
Re: docshare and internal openfire xmpp server [message #624856 is a reply to message #624850] |
Sat, 25 April 2009 11:30 |
news:49EC87FF.7080004@composent.com...
> Hi Marc,
> This suggestion seems completely reasonably to me. Would you mind opening
> a bug for this?...and we'll attempt to get to it as quickly as possible.
> Scott
Hi Scott,
I finally got this done:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=273675
Thanks.
Marc
>> got a bump, and I was able to get docshare working successfully over XMPP
>> on an internal openfire server. However, I ran into some bumps and I'm
>> tried
>> share a file, and the recipient would see my changes. But if the
>> recipient changed the file, the changes would not be reflected on my end.
>> This appears related to the naming stuff discussed in that bug; however,
>> web05.bsg.something.ad.com instead of just web05, it would revert back to
>> from this:
>> to this:
>> page.
>> What do you think?
>> Marc
>>> Hi Scott,
>>> Scott Selvia wrote:
>>> <stuff deleted>
>>> Thanks.
>>> Scott
>>>>> Hi Marc,
>>>>> Scott
>>>>> Marc Esher wrote:
>>>>>> Greetings.
>>>>>> to get this working? the PDE error log isn't showing me anything
>>>>>> suspicious.
>>>>>> thanks!
>>>>>> marc
Current Time: Fri Apr 26 02:43:35 GMT 2024
Powered by FUDForum. Page generated in 0.03391 seconds
