Can't set new file editor: NullPointerException [message #617534] |
Fri, 04 December 2009 11:57 |
fabio T Messages: 4 Registered: December 2009 |
Junior Member |
Hi all,
after googling pretty much and trying the different solutions I found (without success), i hope this is the right place to ask.
I use Eclipse 3.5.1 (galileo) and installed today VisualEditor 1.4. The Installation went good but now I can't use it.
I try to create a java swing application, so my class extends Frame. So, when it starts to create the JFrame, it creates the code but I cant see the raw window and I get this error:
Error trying to set new file into editor
Reason:
When running the code, the window show up and "behaves properly" (there aren't pretty much functionalities right now).
I found a common solution to this bug, which is to close all VE's and make a complete cache cleaning, by doing Project>Clean...>CleanAll . Unfortunately, it does not work for me and I still can't use it.
How can i fix it?
FUDForum. Page generated in 0.01533 seconds
