I don't see the "Visual Class" option after installation [message #616963] |
Sat, 09 February 2008 20:38 |
Originally posted by: chris.keith.gmail.com
Folks-
I am not seeing "Visual Class" under New->Others->Java as an option after
installing VE. I do see: Annotation, Class, Enum, Interface, Java Project,
Java from Ant Buildfile, Package, Source Folder, Tomcat Project, Java
Run/Debug, JUnit. If I go to Help, Plug-in Details, I see what looks like
the appropriate plugins.
I do get an error in the .metadata/.log file:
!SESSION 2008-02-09 12:21:19.750
eclipse.buildId=M20071023-1652
java.version=1.6.0_03
Command-line arguments: -os win32 -ws win32 -arch x86 -data
C:\Alight\inCVS\etc\ck\workspace
!ENTRY org.eclipse.ui.workbench 2 0 2008-02-09 12:21:25.062
!MESSAGE A handler conflict occurred. This may disable some commands.
!SUBENTRY 1 org.eclipse.ui.workbench 2 0 2008-02-09 12:21:25.062
!MESSAGE Conflict for
'AUTOGEN:::org.eclipse.team.cvs.ui.filesystem.ResourceContri butions/org.eclipse.team.examples.pessimistic.addToControl':
HandlerActivation(commandId=AUTOGEN:::org.eclipse.team.cvs.u i.filesystem.ResourceContributions/org.eclipse.team.examples .pessimistic.addToControl,
handler=ActionDelegateHandlerProxy(null,org.eclipse.team.exa mples.pessimistic.ui.AddToControlAction),
expression=WorkbenchWindowExpression(org.eclipse.ui.internal.WorkbenchWindow@d0d12e),sourcePriority=16384)
'AUTOGEN:::org.eclipse.team.cvs.ui.filesystem.ResourceContri butions/org.eclipse.team.examples.pessimistic.removeFromCont rol':
HandlerActivation(commandId=AUTOGEN:::org.eclipse.team.cvs.u i.filesystem.ResourceContributions/org.eclipse.team.examples .pessimistic.removeFromControl,
handler=ActionDelegateHandlerProxy(null,org.eclipse.team.exa mples.pessimistic.ui.RemoveFromControlAction),
I don't understand what "conflict" means here. Both "HandlerActivation"
entries under the "!MESSAGE Conflict" line are the same. Any idea what I
can do to fix this? I tried running the Eclipse.exe with the -clean option
but it didn't make any difference.
Thanks for any help,
Chris Keith
FUDForum. Page generated in 0.03011 seconds
