minor annoyance with change method signature refactor [message #569219] |
Sat, 30 June 2007 22:02 |
Alen Vrecko Messages: 10 Registered: July 2009 |
Junior Member |
am new to Eclipse newsgroups, hope this is the right place to post.
I find Mylyn a pleasure to work with. It is great that it only shows the
stuff that is relevant.
Cheers for the 2.0 release.
But I noticed a very minor annoyance when using the change method
signature refactor. I am using Mylyn 2.0 (same issue with 1.0) under
Eclipse 2.2.1 and have the following problem:
Let say you open X class for editing (opened Java Editor)
Then you wish to use the change method signature refactor, go over
method (ctrl+shift+C) the dialog pops up. And if you use ctrl+space key
on any of the type fields. Then the Java Editor at the back would get
closed. Surprising this always happens if I am editing an Interface and
rarely if a Java file.
While I rarely use change method signature refactor and didn't want to
mention this but there is nothing more annoying than Mylyn closing the
Java editor I am just using. Maybe if somebody could take a look?
Alen
FUDForum. Page generated in 0.03105 seconds
