Re: @Autowired doesn't work when trying to wire a service [message #554047 is a reply to message #554046] |
Thu, 19 August 2010 17:05   |
here is the manifest of the web app that uses the service:
Manifest-Version: 1.0
Class-Path:
Bundle-Name: GUI Web Bundle
Bundle-Version: 1.0
Bundle-SymbolicName: com.rits.gui.web
Web-ContextPath: gui
Bundle-Vendor: RobustIT Solutions
Import-Bundle: com.springsource.org.apache.taglibs.standard;version="[1.1.2,1.1.2] ",
com.springsource.org.apache.log4j;version="[1.2.15,1.3.0)",
com.springsource.org.apache.commons.lang;version="[2.4.0,3.0.0) ",
com.springsource.org.apache.velocity;version="[1.6.2,2.0.0) ",
org.springframework.core;version="[3.0.3.RELEASE,4.0.0)",
org.springframework.web;version="[3.0.3.RELEASE,4.0.0)",
org.springframework.web.servlet;version="[3.0.3.RELEASE,4.0.0) ",
org.springframework.context;version="[3.0.3.RELEASE,4.0.0)",
org.springframework.osgi.core;version="[1.2.1,2.0.0)",
com.rits.virgo.log4j
Import-Package:
org.eclipse.virgo.web.dm;version="[2.0.0.RELEASE,3.0.0.RELEASE) ",
javax.servlet;version="[2.5.0,3.0.0)",
com.rits.config
Export-Package: com.rits.gui.web
Bundle-RequiredExecutionEnvironment: JavaSE-1.6
here is the manifest of the service bundle:
Bundle-ManifestVersion: 2
Bundle-Name: Configuration Service
Bundle-SymbolicName: com.rits.config
Bundle-Version: 1.0.0
Bundle-Vendor: RITS
Import-Bundle: com.springsource.org.apache.log4j;version="[1.2.15,1.3.0)"
Import-Package: groovy.util,groovy.lang
Export-Package: com.rits.config
Re: @Autowired doesn't work when trying to wire a service [message #554048 is a reply to message #554047] |
Thu, 19 August 2010 17:15   |
Try this for web bundle:
Import-Bundle: com.springsource.org.apache.taglibs.standard;version="[1.1.2,1.3)",
com.springsource.javax.servlet.jsp.jstl;version="[1.1.2, 1.1.3)",
Import-Package:
Import-Library: org.springframework.spring;version="${spring.version.range}"
Do you really have to use log4j? Virgo comes with slf4 + logback already. Much nicer combo by the way.
Instead of importing individual spring bundle start out with import library. Minimized from there. At least add
org.springframework.aop;version="${spring.version.range}",
com.springsource.org.aopalliance;version="1.0.0",
org.springframework.beans;version="${spring.version.range}",
org.springframework.core;version="${spring.version.range}",
org.springframework.context;version="${spring.version.range}",
as a minimum set and plus all of the web bundles (i.e. web and web.servlet.
I think the reason that you are missing aop imports could be causing issues with Autowire. You might want to check virgo logs to see if there is some info in there
Also, you shouldn't need to import
unless you are using classes from there in your code.
Dmitry
Re: @Autowired doesn't work when trying to wire a service [message #607731 is a reply to message #554289] |
Sat, 21 August 2010 13:25  |
Thanks, found it, the external repo worked nicely:
ext.type=external
ext.searchPattern=repository/ext/{artifact}
usr.type=watched
usr.watchDirectory=repository/usr
mavenrepo.type=external
mavenrepo.searchPattern=${user.home}/.m2/repository/**/{bund le}.jar
mavenrepolibd.type=external
mavenrepolibd.searchPattern=${user.home}/.m2/repository/**/{ bundle}.libd
chain=mavenrepo,mavenrepolibd,ext,usr
FUDForum. Page generated in 0.06369 seconds
