Re: java.lang.nullpointerexception [message #549136 is a reply to message #549070] |
Sun, 25 July 2010 04:20 |
On 2010.07.23 18:22, mbcluck@gmail.com wrote:
> I actually figured it out. The default editor it was using was no good.
> Instead I have to right click on the file and go to: Open
> With<Androind XML Resource Editor. And now it works fine.
I complained about this a few days ago. The Android XML Resource Editor
is the one that comes up when I double-click the file. I had the same
result as you--having to dismiss a null-pointer error alert between
every keystroke. Using the more graphic approach to modifying my file
hardly worked at (which is why I went to the text editor method).
I wondered if I need to modify my start-up memory amounts.
The Android Layout Editor did not suffer from this problem.
This is disconcerting as Eclipse is supposed to be the primo Android
development environment.
FUDForum. Page generated in 0.09089 seconds
