Home » Modeling » EMF » Teneo: Possibility to use Set-semantics(Teneo: Possibility to use Set-semantics)
Teneo: Possibility to use Set-semantics [message #546942] |
Wed, 14 July 2010 16:57 |
Markus Bohr Messages: 2 Registered: July 2010 Location: Raunheim, Germany |
Junior Member |
I currently use Teneo to bind non-unique EReferences together with Hibernate bag mappings.
What would actually fit better for me would be to introduce a set-semantics to avoid duplicates (giving "true" result for the equals() method) in my lists.
What would I have to do to make this work with Teneo inbetween?
Is it that simple to use the "IS_UNIQUE" constant on EMF side, and set-mapping on Hibernate mapping side, and Teneo makes it work, or is it more complicated?!
EMF side:
initEReference(getCardFormat_Remarks(),
theDomainclassesPackage_99.getRemark(), null, "remarks", null, 0,
-1, CardFormat.class, !IS_TRANSIENT, !IS_VOLATILE, IS_CHANGEABLE,
!IS_COMPOSITE, IS_RESOLVE_PROXIES, !IS_UNSETTABLE, IS_UNIQUE,
!IS_DERIVED, IS_ORDERED);
Hibernate side:
<set name="remarks" where="table_name='CARD_FORMAT'" outer-join="false" inverse="true" lazy="true" optimistic-lock="true" fetch="select" cascade="refresh">
<key on-delete="noaction" unique="false">
<column name="ref_id" sql-type="INTEGER" not-null="true"/>
</key>
<one-to-many class=" com.lhsystems.lido.common.domain.technical.domainclasses.imp l.RemarkImpl " entity-name="Remark"/>
</set>
Re: Teneo: Possibility to use Set-semantics [message #547066 is a reply to message #546942] |
Thu, 15 July 2010 10:48 |
Martin Taal Messages: 5468 Registered: July 2009 |
Hi Markus,
Yes the ereference should be set to unique==true. EMF will not generate a Set collection type so it is not possible to
use the Hibernate <set /> tag (as Hibernate will assume a Set to be used for the type in the generated java).
gr. Martin
On 07/14/2010 06:57 PM, Markus Bohr wrote:
> Hello,
> more complicated?!
> EMF side:
> Hibernate side:
> cascade="refresh">
> </key>
> </set>
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: Teneo: Possibility to use Set-semantics [message #547336 is a reply to message #547277] |
Fri, 16 July 2010 10:44 |
Hi Markus,
Yes, I am not sure how you use EMF, but if you mainly use it server-side (so without the RCP features) then the Texo
project maybe of interest to you. It supports the Set in the generated api (and supports automatic orm generation):
http://wiki.eclipse.org/Texo
gr. Martin
On 07/16/2010 09:57 AM, Markus Bohr wrote:
> Hmm, this a real pity, as <set> on our surrogate keys promises to be far
> more performant than <bag>...
The Netherlands
Current Time: Fri Apr 26 20:19:33 GMT 2024
Powered by FUDForum. Page generated in 0.04579 seconds
