Cannot run program make: unknown reason - Problem with Remote C/C++ Projec [message #545934] |
Fri, 09 July 2010 12:05  |
I've recently updated to Helios and CDT 7.0 and am running into an issue when I create a remote c/c++ project. I can create a remote project (Linux) and compile and run, but it seems to bork environment variables here on my local machine (also Linux). When I try to build a local project I get the error:
(Cannot run program "make": Unknown reason)
as well as the following warning:
Error launching external scanner info generator
Also, i get the following terminal output:
Unable to get $PATH.
Unable to find full path for "make"
Unable to find full path for "gcc"
Here are the steps I took to replicate this error:
1. Clean install of Eclipse, CDT 7.0, Parallel Tools 4, and RSE runtime.
2. Import my project(s) into workspace, local builds are fine.
3. Create a new remote c/c++ project, remote build is fine.
4. Attempt to build local project, receive above errors. The same thing happens if I create a new local project.
5. The remote project is still able to build fine.
6. I can build my local project if I edit the project properties -> C/C++ Build -> Environment and add my PATH.
So it seems I can solve my problem, but my concern is am I just putting a band-on a underlying problem? Is there some configuration I need to edit? Is this a bug? I've tried to search but most of the results deal with people who have problems installing mingw on windows.
Thanks in advance.
Re: Cannot run program make: unknown reason - Problem with Remote C/C++ Projec [message #653091 is a reply to message #547456] |
Tue, 08 February 2011 08:18  |
I have the same problem, I tried to add path to my .bashrc (despite is redundant) and to generate a symbol into the project environment, but any of them worked for me.
When Eclipse starts, the messages:
Unable to find full path for "g++"
GC Warning: Out of Memory! Returning NIL!
Are shown
To get it working, I forced as suggested in other posts of this site the following:
Open the project properties; Under C/C++ Build uncheck the "use default build command" and change the build command.
/usr/bin/make
When linking, the message: cannot find 'ld' appears,
a solution:
http://www.prog.org.ru/index.php?topic=12076.msg76207
It is in russian, but it basically suggest adding:
"g++ -B/usr/bin"
(or "gcc -B/usr/bin" in my case)
to the linker command (Project Properties-> C/C++ Build -> Settings->GCC C Linker->Command
It is working, generating an executable, but I still get the mentioned "unable to get $PATH", etc and besides, the debug executable cannot run from inside the environment but from a terminal it runs... into the environment claims that "binary not found"..
Any help with the paths problems and the debugging will be welcome. Thanks in advance.
FUDForum. Page generated in 0.67478 seconds
