Helios JEE: subversive installed but does not show up [message #544308] |
Fri, 02 July 2010 09:54 |
Reynald Borer Messages: 4 Registered: July 2010 |
Junior Member |
Hello all,
I am facing a very strange issue that is quite annoying. I have recently downloaded and installed Eclipse Helios release, more specifically the Eclipse IDE for Java EE Developers package. After having launched it, I installed the "Subversive - SVN Team Provider" feature through Eclipse market place, and restarted Eclipse.
There was no error during installation, but now I cannot see anywhere any reference to this plugin, as if it was not enabled. If I check for the installed features, I can see the plugin is here, and seems to be correctly started.
I remember that I also had this problem with Eclipse 3.5 Java EE version, and I had to stick with the classic package and install all required plugins to see the subversive features enabled.
Is there a known incompatibility between the JEE package and subversive ?
Thanks for your help,
Reynald
P.S: I am running under Linux, maybe this has an impact.
FUDForum. Page generated in 0.04005 seconds
